I encountered multiple problems installing libraries (to python) that have many dependencies..at some point I think it just crashed,
now it boots only to terminal window starting from login. Meanwhile, I relocated to many places, so the internet is lost.
Can anyone guide me:
  1. to connecting the internet, (I can't get the ip route to return anything, ifconfig to work without net-tools that must be installed using sudo apt, which requires internet..oh the vicious cycle)
    resolved with the command
    nmcli dev wifi connect <mySSID> password <myPassword>
  2. reviving the GUI features that normally worked .. I didn't install server version obviously.
    Tried:
    sudo apt-get install compizconfig-settings-manager
    from Fix user interface (Ubuntu Unity) disappearing problem after upgrade to Ubuntu 16.04
DISPLAY:=0 ccsm & directs me to a library gtk under python2.7. Returned a msg in line with Nonetype cannot bring default screen
when running sudo apt upgrade --fix-missing
Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/g/gdm3/libgdm1_3.28.2-0ubuntu1.3_amd64.deb 404 Not Found & the like, grub2
David Foerster
  • 36,890
  • 56
  • 97
  • 151
dia
  • 113
First get your packages sorted out
If you are getting errors downloading packages, you need to enable mirrors:
How can I get apt to use a mirror close to me, or choose a faster mirror?
Then run:
sudo apt update && sudo apt upgrade --fix-missing
This should fix any broken things with apt and your package library.
Next, reinstall the GUI
sudo apt install --reinstall ubuntu-session gdm3
sudo dpkg --configure -a
sudo dpkg-reconfigure gdm3
Start the X server
You can now reboot or start the server manually to make sure it works:
startx
