Given:
  1. I have a tree structure with folders EmptyMe on different levels
  2. EmptyMe directories contain sub-directories and files
Required:
  1. Empty contents of EmptyMe directories (including their sub-directories), while keeping those directories (not deleting them).
Question:
What's the Unix command to recursively find all EmptyMe directories from current level and delete all of their contents (including sub-directories), while keeping EmptyMe directories on the disc?
My attempt:
$ find . -name 'EmptyMe' -type d -exec rm -- {} +
rm: cannot remove `./a/b/c/d/EmptyMe': Is a directory
As you can see, that command attempted to remove EmptyMe, as opposed to its contents.
Kevin Bowen
  • 20,055
  • 57
  • 82
  • 84
temuri
  • 185
Test run:
find . -path '*/EmptyMe/*'
Real deletion:
find . -path '*/EmptyMe/*' -delete
-path '*/EmptyMe/*' means match all items that are in a directory called EmptyMe.
wjandrea
  • 14,504
One option that can be used is to nest the commands:
find . -type d -name 'EmptyMe'  -exec find {} -mindepth 1 -delete \;
The outer find -type d -name 'EmptyMe' locates the required directories, and runs the inner find command via -exec ... \;. The inner command descends into the found directory (referenced via {} ) and since we're using -delete flag here, it should follow depth-first search, removing files and then subdirectories.
wjandrea
  • 14,504
This works, but it gives errors if EmptyMe directories are empty.
find . -name 'EmptyMe' -type d -exec sh -c 'rm -r -- "$1"/*' sh {} \;
Error example:
rm: cannot remove ‘./EmptyMe/*’: No such file or directory
wjandrea
  • 14,504
