Tried to add language through the normal interface but it doesnt work. When I"m swiching to it, it still writes in English.
Found this way to do it
aptitude -y install check-language-support -l ru
but it throws errors. How should I downgrade installed packages?
root@user:/home/user# aptitude -y install check-language-support -l ru
    The following NEW packages will be installed:
      gnome-getting-started-docs-ru{b} gnome-user-docs-ru{b}
    0 packages upgraded, 2 newly installed, 0 to remove and 15 not upgraded.
    Need to get 11,1 MB of archives. After unpacking 14,9 MB will be used.
     gnome-user-docs-ru : Depends: gnome-user-docs (= 3.28.1-0ubuntu1) but 3.28.2+git20180715-0ubuntu0.1 is installed
     gnome-getting-started-docs-ru : Depends: gnome-getting-started-docs (= 3.28.1-0ubuntu1) but 3.28.2-0ubuntu0.1 is installed
    The following actions will resolve these dependencies:
         Keep the following packages at their current version:
    1)     gnome-getting-started-docs-ru [Not Installed]
    2)     gnome-user-docs-ru [Not Installed]
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 15 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
Tried to install those packages with targeted versions, they are not installing
apt-get install gnome-getting-started-docs-ru=3.28.1-0ubuntu1
N0rbert
  • 103,263
Your current method
For me it is clear that you are trying to pass output of the check-language-support -l ru command to aptitude, but doing this wrong.
The correct way is:
sudo aptitude -y install $(check-language-support -l ru)
Note $(...) above - it executes the command and then passes the output as the argument to the aptitude.
Fixing problems with your current method
You can fix your package errors with the following
sudo aptitude update
sudo aptitude install -f
sudo aptitude dist-upgrade
Installing languages in GUI way
I recommend to install languages in GUI-way:
  1. Open GNOME Control Center (for example from right corner of the screen):
  2. Go to Region and Language
    GNOME Control Center language
  3. Click on Manage Installed Languages
  4. Confirm installation of non-installed components:
    language support
    and wait it to finish.
  5. Click on Install / Remove Languages, then scroll list to Russian and check it:
    Selecting Russian
    and click Apply. Wait it to finish.
  6. Scroll Language for menus and windows list to русский, drag it and drop to the first line.
  7. Close Language Support window and log-out.
  8. Log-in again.
  9. Apply folder renames
    folder rename
    by clicking Обновить имена.
  10. Enjoy!
If you need to add Russian keyboard layout - do the following:
  3. In the Input Sources click add button (add layout)
  4. Click on More (More) and search for Russian:
    adding Russian
    then click Add.
  5. Enjoy!
Note: default keyboard layout switcher is Super+Space, you may chose other combinations from GNOME Tweak Tool (with some limitations on Ctrl+Shift).
N0rbert
  • 103,263
To conclude my question. I managed to install required packages only with Synaptic package manager at the second or third try. Then it installed full language support and after relog it started typing in Russian.
