i'm trying to install postgresql-10 via the instructions listed here:
https://www.postgresql.org/download/linux/ubuntu/
I'm trying to run this step and I keep getting the following unmet dependency errors:
$ sudo apt install postgresql-10
Reading package lists... Done
Building dependency tree
postgresql-10 : Depends: postgresql-client-10
Depends: libgssapi-krb5-2 (>= 1.14+dfsg) but 1.13.2+dfsg-5ubuntu2 is to be installed
Depends: libicu57 (>= 57.1-1~) but it is not installable
Depends: libpq5 (>= 9.3~) but it is not going to be installed
I'm unsure of how to exactly correct these problems, i've tried running sudo apt update && sudo apt upgrade
What is the appropriate way to update these packages to get postgresql-10 installed on my ubuntu 16.04 instance?
EDIT:
when I try manually installing those dependencies:
$ sudo apt install libgssapi-krb5-2
[sudo] password for chris:
libgssapi-krb5-2 is already the newest version (1.13.2+dfsg-5ubuntu2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
