I am setting up a laptop for someone. It has 2GB memory (and a swap partition in case it helps) which boots very slowly. This list shows all the processes which take over ten seconds from system-analyze blame:
1min 30.200s nmbd.service
     52.468s apt-daily.service
     32.414s plymouth-start.service
     31.853s plymouth-quit-wait.service
     31.848s lightdm.service
     26.335s plymouth-read-write.service
     14.025s dev-sda1.device
     12.957s ufw.service
     11.176s systemd-journal-flush.service
I've been advise by the Ubuntu Budgie people that I can:
  1. Remove nmbd.service as there is no intention to connect to Windows computers. How would I do this?
  2. Fix the way apt-daily.service starts - this shouldn't be happening until later anyway. A couple of ways to do this are discussed here Ubuntu 16.04 slow boot (apt-daily.service). One suggestion times out the initial attempt to start the service and the other postpones it till long after boot has finished. Would either be satisfactory?
Artur Meinild
  • 31,035
You can disable the nmbd service, though you could also just uninstall samba. It would also help to know how long 'very slowly' is as this is very relative. Apart from that - as far as I know most of these services start independently, so even though nmbd takes a long time, it doesn't stop other services.
edit: Other items that you could try to disable/stop: graphical boot screen (plymouth) or ufw (firewall likely not enabled by default anyway)
I think the bigger problem is probably that the laptop is relatively slow in general, with only 2 GB RAM and likely (I suspect) only a slow hdd and not a faster one or an ssd. So a more permanent solution would be to try to get a cheap ssd, this will increase your startup time much more than trying to kill a process here or there.
step21
Stopping neither made any difference, presumably they weren’t holding anything else up. I tried Standard Ubuntu in desperation - same problem. What fixed it was this: Boot very slow because of drm_kms_helper errors
This is a bug. To avoid delay you can use workaround. From terminal run:
    sudo nano /etc/default/grub
Then add the kernel boot parameter: video=SVIDEO-1:d , so it will look like this: GRUB_CMDLINE_LINUX_DEFAULT="quiet splash video=SVIDEO-1:d"
    sudo update-grub
    sudo reboot
