17
I installed Ubuntu on a disk partition just two days ago and everything work like a charm. The only problem I'm having is with the screen temperature color. In Windows I use f.lux and I set the color temperature as red as possible (3500K) all-day-long. I want to do the same in Ubuntu but I faced many issues:
  • f.lux doesn't change the color at all
  • Redshift changes the temperature for a couple of seconds, then it suddenly goes back to the normal color
  • GNOME Night Light has the same problem of Redshift: the change is not permanent although I set the color temperature to be 3500K from 5AM to 3AM
Is anyone having the same problem? How can I fix it?
System info:
  • Ubuntu 18.04.1 LTS
  • GNOME 3.28.2
  • External monitor HP 24" 60,00 Hz
Brigo
  • 271
I found that for Night Light I have to set it to manual mode and set the start time to some time before the current time and the end time sometime before the end time.
I was perplexed for a while because I assumed that, like all other widgets in Ubuntu, setting the switch to on (green) would just turn Night Light on.
Try un-installing redshift, then use a night light.
I was also having some issues with redshift, couldn't get it to work. So then I tried night light - the colour temperature would flash on for a second and then off again...periodically.
I think there might have been a conflict with redshift, because after I uninstalled it from the command line with
sudo apt-get remove redshift
then the colour temperature on night light seemed to work as expected.
edge-case
  • 181
