After going from 10.04 - 10.10 (not upgraded, completely reinstalled because of upgrade issues) I found a weird problem with my mouse pad. Whenever I clicked on the left or right mouse buttons (integrated into the touch pad) when I released them, it seemed like it was detecting a double click and ended up choosing the option the mouse was hovering over.
Has anyone else experienced issues like this, and if it is possible, could I fix it?
Jorge Castro
  • 73,717
daxvena
  • 989
There could be a number of reasons for a double click, sometimes it's hardware failure and sometimes it's software. If you tend to get a double click every time then it's more likely to be software.
You can check your mouse configuration from the command line by typing in:
xinput list
This should give you a list of mice connected to your system, one might be your dell touchpad. If you see two entries that seem to be the same device, then that might be the issue. Of course it's hard to know without your showing the results of the above command in your original post.
Either way you should certainly report the issue if it remains by typing in the following command:
ubuntu-bug xorg
Explain in the bug your problems.
