I am using grub4dos 0.4.4 to boot Ubuntu 17.04 successfully. Here are lines in the file MENU.LST
title Ubuntu 17 (64bit)
fallback 6
find --set-root /iso/ubt1704.iso
map --mem /iso/ubt1704.iso (0xff) || map --heads=0 --sectors-per-track=0 /iso/ubt1704.iso (0xff)
map --hook
root (0xff)
kernel /casper/vmlinuz.efi  file=/cdrom/preseed/ubuntu.seed boot=casper iso-scan/filename=/iso/ubt1704.iso splash
initrd /casper/initrd.lz
But for Ubuntu 18.04, they did not work. The computer restarted after menu Ubuntu 18.04 was selected.
Please help me to fix the problem. Thanks in advanced.
Update on 15-Aug-2018.
I have changed the content of MENU.LST as bellow and it worked.
find --set-root /iso/ubt1804.iso
map --mem /iso/ubt1804.iso (0xff) || map --heads=0 --sectors-per-track=0 /iso/ubt1804.iso (0xff)
map --hook
root (0xff)
kernel /casper/vmlinuz file=/cdrom/preseed/ubuntu.seed boot=casper iso-scan/filename=/iso/ubt1804.iso splash
Alexxus
  • 103
Using grub4dos to boot Ubuntu Ubuntu 18.04 ISO disk image, here is the entry for the file MENU.LST:
title Ubuntu 18
  fallback 6
  map --hook
  root (0xff)
NB,
  • For Ubuntu 64bit from 14.04 to 17.10 vmlinuz.efi was used, so kernel has to be /casper/vmlinuz.efi, but
  • For older versions and 18.04+ use /casper/vmlinuz
  • For Ubuntu 32bit, it has always been vmlinuz
  • For smaller ISO disk images, or your RAM is extremely big, you can use --mem for the map command to put the whole disk into system memory, like this:
    map --mem /iso/smallcd.iso (0xff) || map --heads=0 --sectors-per-track=0 /iso/smallcd.iso (0xff)
Ref: here
xpt
  • 1,197
