The & operator is specially used for executing a task in background, representing like you see (with the [X] YYYY). YYYY is the PID number of the task in background, and X is the number you assigned at this background task (like a counter).
PID will change every time, it will increment itself like a counter, and X would be reset when you will close the terminal. If you type kill -9 YYYY where YYYY is the PID number of this background task; terminal will prompted [X] Stopped, that means your background task is ... stopped.
There is no problem with that, just a little mistake from your command, which would be sudo apt-get update && sudo apt-get upgrade -y.
NB: Usually, when you use a command line (without the & operator), you can't use another one in the same terminal unless the command line is done, but when you add the & operator, the terminal will accept another command at same time (but without output and error redirection, it can be hard to type something, so you can also use nohup).
