I attempted to upgrade Ubuntu 14 to 16 LTS using sudo do-release-upgrade and everything is broken. The installation is not completed. The logs say it was aborted. When I use apt or apt-get the following output is shown (see below). It seems installation of some packages have left incomplete. All attempts failed.
I managed to chroot into an Ubuntu 16 from CDROM (in fact from HDD) and fixed a few things. But I cannot install the new kernel. (from How to restore a system after accidentally removing all kernels?)
Various things I tried:
  • sudo dpkg --configure t
  • apt-get -f install
  • dpkg -l | grep -v '^ii'|cut -c5-64 >list-of-packages.txt
  • dpkg --configure $(
  • sudo dpkg --configure -a
  • Replaced sources.list with the original file.
  • sudo apt-get install --fix-broken
  • sudo do-release-upgrade # No new release found.
Output of uname -a
Linux ubuntu 4.15.0-29-generic #31~16.04.1-Ubuntu SMP Wed Jul 18 08:54:04 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
Output of: ls /etc/apt/sources.list.d
arangodb.list github_git-lfs.list.save
nodesource.list.distUpgrade
staticfloat-juliareleases-trusty.list.distUpgrade arangodb.list.distUpgrade google-chrome.list
nodesource.list.save staticfloat-juliareleases-trusty.list.save arangodb.list.save google-chrome.list.distUpgrade
paolorotolo-droidcam-trusty.list tualatrix-ppa-trusty.list d-apt.list google-chrome.list.save
paolorotolo-droidcam-trusty.list.distUpgrade
tualatrix-ppa-trusty.list.distUpgrade d-apt.list.distUpgrade
google-cloud-sdk.list paolorotolo-droidcam-trusty.list.save
tualatrix-ppa-trusty.list.save d-apt.list.save
google-cloud-sdk.list.distUpgrade rabbitmq_rabbitmq-server.list
ubuntu-toolchain-r-test-trusty.list docker.list
google-cloud-sdk.list.save
rabbitmq_rabbitmq-server.list.distUpgrade
ubuntu-toolchain-r-test-trusty.list.distUpgrade docker.list.distUpgrade linrunner-tlp-trusty.list sbt.list
ubuntu-toolchain-r-test-trusty.list.save docker.list.save
linrunner-tlp-trusty.list.distUpgrade sbt.list.distUpgrade
webupd8team-java-trusty.list erlang-solutions.list
linrunner-tlp-trusty.list.save sbt.list.save
webupd8team-java-trusty.list.distUpgrade erlang-solutions.list.distUpgrade neo4j.list
staticfloat-julia-deps-trusty.list
webupd8team-java-trusty.list.save erlang-solutions.list.save
neo4j.list.distUpgrade
staticfloat-julia-deps-trusty.list.distUpgrade webupd8team-unstable-trusty.list github_git-lfs.list
neo4j.list.save staticfloat-julia-deps-trusty.list.save
webupd8team-unstable-trusty.list.distUpgrade github_git-lfs.list.distUpgrade nodesource.list
webupd8team-unstable-trusty.list.save
sudo dpkg --configure -a Output along list including the following lines:
... dpkg: error processing package libstdc++6:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of libkwalletbackend5-5:amd64: libkwalletbackend5-5:amd64 depends on libstdc++6 (>= 5.2); however:
Package libstdc++6:amd64 is not configured yet.
dpkg: error processing package libkwalletbackend5-5:amd64 (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of gstreamer1.0-plugins-good:amd64: gstreamer1.0-plugins-good:amd64 depends on libstdc++6 (>= 4.1.1); however: Package libstdc++6:amd64 is not configured yet. ... Processing was halted because there were too many errors.
The output I get when I do any apt-like command (e.g. sudo apt install linux-image-generic ) is the following:
sudo apt install linux-image-generic Reading package lists... Done Building dependency tree Reading state information... Done You
might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: click : Depends: python3-click (= 0.4.21.1ubuntu0.2) but 6.2-2ubuntu1 is to be installed empathy : Depends: libcheese-gtk23 (>= 3.4.0) but it is not installable Depends: libcogl15 (>= 1.15.8) but it is not installable Recommends: telepathy-haze but it is not going to be installed Recommends: gnome-contacts but it is not going to be installed Recommends: nautilus-sendto-empathy but it is not installable gstreamer1.0-clutter : Depends: libcogl15 (>= 1.15.8) but it is not installable libbaloofiles4 : Depends: libxapian22 but it is not installable libbalooxapian4 : Depends: libxapian22 but it is not installable libc6:i386 : Depends: libgcc1:i386 but it is not going to be installed libgcc1 : Depends: gcc-6-base (= 6.0.1-0ubuntu1) but it is not going to be installed libgfortran3 : Depends: gcc-6-base (= 6.4.0-17ubuntu1~14.04) but it is not going to be installed libgl1-mesa-dri:i386 : Depends: libgcc1:i386 (>= 1:3.4) but it is not going to be installed Depends: libstdc++6:i386 (>= 5.2) but it is not going to be installed libicu55:i386 : Depends: libgcc1:i386 (>= 1:4.2) but it is not going to be installed Depends: libstdc++6:i386 (>= 5.2) but it is not going to be installed libjack-jackd2-0:i386 : Depends: libgcc1:i386 (>= 1:4.1.1) but it is not going to be installed Depends: libstdc++6:i386 (>= 5.2) but it is not going to be installed libllvm3.8v4:i386 : Depends: libgcc1:i386 (>= 1:4.1.1) but it is not going to be installed Depends: libstdc++6:i386 (>= 4.8) but it is not going to be installed libllvm6.0:i386 : Depends: libgcc1:i386 (>= 1:4.2) but it is not going to be installed Depends: libstdc++6:i386 (>= 5.2) but it is not going to be installed libmysqlclient18:i386 : Depends: libgcc1:i386 (>= 1:4.1.1) but it is not going to be installed libmysqlclient20:i386 : Depends: libgcc1:i386 (>= 1:4.2) but it is not going to be installed Depends: libstdc++6:i386 (>= 5.2) but it is not going to be installed libqapt2-runtime : Depends: libqapt2 (>= 1.9.60) but it is not installable libqt4-declarative : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-declarative:i386 : Depends: libgcc1:i386 (>= 1:4.2) but it is not going to be installed Depends: libqtcore4:i386 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed libqt4-designer : Depends: libqt4-xml (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-dev : Depends: libqt4-xml (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: qt4-qmake (= 4:4.8.7+dfsg-5ubuntu2) libqt4-dev-bin : Depends: libqt4-xml (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-help : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-network : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-network:i386 : Depends: libgcc1:i386 (>= 1:4.2) but it is not going to be installed Depends: libqtcore4:i386 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed libqt4-opengl : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-opengl:i386 : Depends: libgcc1:i386 (>= 1:4.2) but it is not going to be installed Depends: libqtcore4:i386 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed libqt4-qt3support : Depends: libqt4-xml (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-script : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-script:i386 : Depends: libgcc1:i386 (>= 1:4.2) but it is not going to be installed Depends: libqtcore4:i386 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed libqt4-scripttools : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-sql : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-sql:i386 : Depends: libgcc1:i386 (>= 1:3.0) but it is not going to be installed Depends: libqtcore4:i386 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed libqt4-sql-mysql:i386 : Depends: libgcc1:i386 (>= 1:3.0) but it is not going to be installed Depends: libqtcore4:i386 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed libqt4-sql-sqlite : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-svg : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-test : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-xml:i386 : Depends: libgcc1:i386 (>= 1:4.1.1) but it is not going to be installed Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed libqt4-xmlpatterns : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqt4-xmlpatterns:i386 : Depends: libgcc1:i386 (>= 1:4.2) but it is not going to be installed Depends: libqtcore4:i386 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed libqtcore4:i386 : Depends: libgcc1:i386 (>= 1:4.1.1) but it is not going to be installed Depends: libstdc++6:i386 (>= 4.6) but it is not going to be installed libqtdbus4 : Depends: libqt4-xml (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqtdbus4:i386 : Depends: libgcc1:i386 (>= 1:3.0) but it is not going to be installed Depends: libqt4-xml:i386 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libqtcore4:i386 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed libqtgui4 : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed libqtgui4:i386 : Depends: libgcc1:i386 (>= 1:4.2) but it is not going to be installed Depends: libqtcore4:i386 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed Recommends: qt-at-spi:i386 but it is not going to be installed libqtwebkit4:i386 : Depends: libgcc1:i386 (>= 1:4.1.1) but it is not going to be installed Depends: libstdc++6:i386 (>= 5.2) but it is not going to be installed libstdc++6 : Depends: gcc-8-base (= 8.2.0-3) but 8.1.0-5ubuntu1~14.04 is to be installed Breaks: libboost-date-time1.54.0 but 1.54.0-4ubuntu3.1 is to be installed Breaks: python-scipy (<= 0.14.1-1) but 0.13.3-1build1 is to be installed libsystemd0:i386 : PreDepends: libgcc1:i386 (>= 1:4.2) but it is not going to be installed libtxc-dxtn-s2tc0:i386 : Depends: libstdc++6:i386 (>= 4.1.1) but it is not going to be installed libubuntu-location-service0 : Depends: libgflags2 but it is not installable Depends: libgoogle-glog0 but it is not installable libudev1:i386 : Depends: libgcc1:i386 (>= 1:4.2) but it is not going to be installed qdbus : Depends: libqt4-xml (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed qt4-linguist-tools : Depends: libqt4-xml (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but 4:4.8.5+git192-g085f851+dfsg-2ubuntu4.1 is to be installed ubuntu-system-settings : Depends: qtdeclarative5-ubuntu-settings-components (> 0.7+15.04.20160310) but 0.1+14.04.20140306-0ubuntu1 is to be installed Depends: suru-icon-theme (>= 14.04+15.04.20150813~) but 14.04+14.04.20140410-0ubuntu1 is to be installed Depends: system-image-dbus (>= 3.1) but 2.2-0ubuntu1 is to be installed Depends: ubuntu-keyboard-data (>= 0.99.trunk.phablet2+15.04.20150421) but 0.99.trunk.phablet2+14.04.20140415-0ubuntu1 is to be installed xchat-gnome : Depends: libperl5.18 (>= 5.18.2) but it is not installable zeitgeist-core : Depends: libxapian22 but it is not installable E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Sohail Si
  • 113
The repository may have been corrupted. You can use the following command to clean out your apt list:
sudo rm -r /var/lib/apt/lists/*
Then update with
sudo apt update
checkout your /etc/apt/sources.list and all files into /etc/apt/sources.list.d/ for duplicates or invalid packages
apt-get clean
and then
apt-get update && apt-get dist-upgrade
