stuck on this issue for 4 days, would appreciate any help!
So, I am trying to install Dual Boot of Win10 and Ubuntu18 on my Acer Aspire V15 (VN7-592G). If I plug in the USB drive, it won't boot the Linux installation screen, always only to Windows.
I tried everything I could find online to fix it:
  1. Deactivate Fast Start Up in Windows.
  2. Deactivate Secure Boot in BIOS Settings.
  3. Reduce Volume of C: by the half. The other half (D:) is a GPT.
  4. Make Bootable Stick with RUFUS and the official Ubuntu18 ISO. I used GPT as partition scheme, the target system UEFI(without CSM), the type FAT32 and the size 8GB - as the RUFUS settings.
  5. Activate F12 Menu in BIOS Settings.
  6. Changing Boot Priority of USB HDD to First. Now I tried both ways: 7a. Turning laptop on and pressing F12. Then selecting "Command Linpus Lite (Generic Flash Disk)" or "Linpus lite (Generic Flash Disk)" 7b. Turning laptop on without F12 (as I changed the boot priority already).
So the weird thing is, the laptop recognizes the Flash drive in the "F12 Menu", but won't boot from it, even though I select it. It will just start Windows and show my login screen. Also, when I plug in a Win Installer on USB (Tried Win8), it is able to boot the installation menu without issues. (I also tried a Ubuntu14 bootable USB stick, but this didn't work neither. Even though, here it at least shows the common screen "Try Ubuntu"/ "Install Ubuntu", but then the screen stays black - won't do anything.)
Some background info: I have the laptop for 6 days (it was second hand from Amazon Warehouse). The moment I unpacked it, the originial Win10 was so slow (with all that extra programs that I don't need from Acer), so I spent two days trying to install Ubuntu. This finally worked by following these instructions:
*"Detailed steps I used to successfully install:
  • Create a boot USB with the Ubuntu image file using Rufus as detailed here:https://www.ubuntu.com/download/desktop/create-a-usb-stick-on-windows
  • Insert USB in the forward left hand side USB connector (the USB connector on the right side of the computer will not work)
  • Reboot the computer and access the BIOS with F2: Use arrow keys to navigate to BOOT screen
  • Select Secure Boot and change value to disable
  • On the Boot priority order move USB-HDD to the top F10 to save and exit
  • Proceed with the installation type of choice
After the installation has completed, and is prompting you to restart:
  • Remove the USB drive (on reboot)
  • Access the BIOS again with F2 On the
  • BIOS page Select an UEFI file as trusted for executing Navigate to: HDD0 > EFI > 'ubuntu' and select SHIMX64.EFI (Enter shimx64 as name)
  • Navigate to the BOOT tab: Select Secure boot, change value to Enabled
  • F10 to save and exit
I followed these exact steps, installed without errors, and am using Ubuntu on my Acer V3 now."*
------------ How to install Ubuntu on an Acer with preinstalled Windows 10 Home (11.08.2018)
Though to the fact that I need Dual Boot, I needed to have Windows installed first, so I installed Win8 (what I usually prefer over Win10). Installing it worked easily, but I then had issues with the drivers as Acer only provides them for Win10, and I couldn't find ones for my network and sound card, so I installed Windows 10 using the official Win10 ISO from Microsoft.
It's not the first time I am working with BIOS, OS, etc. I am usually doing that without issues on SONYs, DELLs, etc. but this Acer is driving me crazy!!
Any idea what I could have missed?
I really don't want to give up on this one, as I - given the hardware specs - got this laptop really cheap from amazon's warehouse (it was second hand, though looks as new).
Thanks a lot
PS: Laptop details:
Intel Core I7 6th Gen // 16 GB RAM // 1TB HDD //NVIDIA GEFORCE GTX 960 4 GB // 4K (3840 x 2160) -> Maybe it's due to some resolution issues?
Kyrill
  • 329
