I want to build and install snaps locally, not from the Snap Store. For example, snap install foo should fail and Snap Store apps should not appear in GNOME Software.
How can I keep Snap, but disable/remove the Snap Store?
You could firewall off the store by setting all the host names the store uses to 127.0.0.1 in your /etc/hosts file. That way you get to keep the ability to build and install snaps locally, but snapd will never reach the store.
Adding 127.0.0.1 api.snapcraft.io to /etc/hosts will likely be sufficient.
