I have just upgraded to 18.04 and am trying to install upgrades and or new programd via the terminal. I get the following message
digikam-private-libs : Depends: libkf5sane5 (>= 4.3.4) but it is not going to be installed
                        Depends: libqtav1 but it is not going to be installed
                        Depends: libqtavwidgets1 but it is not going to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
i have tried  sudo apt --fix broken install and get this message.dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Preparing to unpack .../libqtav1_1.12.0+ds-4build3_amd64.deb ...
Unpacking libqtav1:amd64 (1.12.0+ds-4build3) ...
dpkg: error processing archive /var/cache/apt/archives/libqtav1_1.12.0+ds-4build3_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/libQtAV.so.1', which is also in package libqtav:amd64 1.11.0~git170314-xenial~ppa1
Preparing to unpack .../libqtavwidgets1_1.12.0+ds-4build3_amd64.deb ...
Unpacking libqtavwidgets1:amd64 (1.12.0+ds-4build3) ...
dpkg: error processing archive /var/cache/apt/archives/libqtavwidgets1_1.12.0+ds-4build3_amd64.deb (--unpack):
 trying to overwrite '/usr/lib/x86_64-linux-gnu/libQtAVWidgets.so.1', which is also in package libqtavwidgets:amd64 1.11.0~git170314-xenial~ppa1
 /var/cache/apt/archives/libkf5sane5_17.12.3-0ubuntu1_amd64.deb
I have tried to apt remove digikam and apt purge digikam and recieved this message
 Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
I have tried to install aptitude and get the same message. Digikam appears as not installed in the Software center and when I press install I get an error message.Everything seem to work fine other than that. Thanks a bunch,,,,,Jacques
N0rbert
  • 103,263
It seems that there are packaging errors between two (16.04 and 18.04) releases.
So we can force installation of these packages:
sudo dpkg -i --force-all /var/cache/apt/archives/libkf5sane5_17.12.3-0ubuntu1_amd64.deb
sudo dpkg -i --force-all /var/cache/apt/archives/libqtav1_1.12.0+ds-4build3_amd64.deb
sudo dpkg -i --force-all /var/cache/apt/archives/libqtavwidgets1_1.12.0+ds-4build3_amd64.deb
And then resume package installation with
sudo dpkg --configure -a
sudo apt-get install -f
For sure upgrade all package dependencies and reinstall your packages with
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install --reinstall libkf5sane5 libqtav1 libqtavwidgets1
N0rbert
  • 103,263
