I tried installing R on 16.04 LTS and I get the below error. I tried all possible solutions given in various forums with no luck. Please suggest.
sak@bav:~$ sudo apt-get install r-base
Reading package lists... Done
Building dependency tree
requested an impossible situation or if you are using the unstable distribution
that some required packages have not yet been created
  r-base : Depends: r-base-core (>= 3.5.1-1xenial) but it is not going to be installed
           Depends: r-recommended (= 3.5.1-1xenial) but it is not going to be installed
           Recommends: r-base-html but it is not going to be installed
wjandrea
  • 14,504
ulab
