It's working on my browser but it doesn't work on my Kubuntu 18.04 I installed all the keys and stuff they recommended then installed the windscribe-cli and signed in, when I try to connect it says firewall enabled and under it there's a spinning thingy that doesnt stop like it can't connect. Can you help me fix the issue?
The problem is on my Linux because I can connect to their servers when I use the browserscreenshot
Edit: I have UFW blocking all incoming connections, could it be causing the problem?
Edit2: I disabled UFW and I still can't connect to the VPN :(
I use Windscribe on Ububtu 18.04 and I have noticed that once you are logged in you remain logged in and also once enabled the firewall stays enabled ( the windscribe firewall blocks all internet access when not connected to a windscribe server), even after a restart. I would recommend disabling the firewall with the commend "windscribe firewall off" then try to reconnect then after connection turn the firewall back on. Alternately try a different location from the locations list but remember to use the pseudonym for example "windscribe connect castle" is Frankfurt Germany.
MeInBG
Disabling the firewall is defeating the purpose of using a VPN ( your IP address won't change). This what I did to make it work again in Ubuntu 18.04:
Remove resolvconf and then reinstall it:
sudo apt-get remove --purge resolvconf && sudo apt-get install resolvconf
Don't forget to reboot!
Melchia
  • 279
Small note: The firewall has literally no impact on whether you're using a VPN or not. The Firewall is basically just a killswitch; it kills your connection if your vpn connection is disrupted/lost, so you don't connect using your own connection.
Ecka
