I cannot access my photos stored on my Samsung S7 using Ubuntu 18.04. I know this question has been asked before, and I tried all of the solutions offered (e.g, trying a different USB port, different USB cable, installing mtp libraries, changing the setting on my phone etc.), and nothing has worked. After I plug the phone into my computer via USB, the computer recognizes it as a Samsung. Then I navigate to the folder where I want to get my photos from, and the file manager just freezes. I can't even unmount the device. I have to do it via unplugging the USB cable.
I bought this computer specifically for blogging, and I need to be able to get my photos on. :(
Installing the exfat-utils repository worked for me. It seems that Ubuntu/Unix has problems accessing the Fat32 formatted SD card and even the phone's memory. After installing the exfat-utils from here I could access the SD card, main memory, and images of my Galaxy S7 without problems.
Important! If you ever connected the phone to a Windows OS make sure to "safely remove" it before unplugging the USB and connecting to Ubuntu. Otherwise, Ubuntu will not be able to handle it.
Here are the terminal commands as given by the authors of the package (make sure you have all relevant packages installed as listed in the link):
git clone https://github.com/relan/exfat.git
cd exfat
autoreconf --install
./configure
make
Then install driver and utilities (from root):
make install
You can remove them using this command (from root):
make uninstall
Do not forget to press "Allow" on your phone's popup window after establishing the USB connection.
As I can't comment yet: JohannesE is correct, but you need to reload your gnome session too. Complete instructions:
sudo apt install exfat-utils
Reboot or simply logout / login. Plugin your S7 phone and select USB file transfer mode.
FYI: picture mode was working fine as it has a 4GB file limit (FAT). But to load videos, larger files need to be supported too (exFAT).
