I would like to be able to back up all my settings and files to a dedicated external hard drive in a way that makes (1) all the backup files accessible and (2) would allow me to restore my system is there is a crash.
Is there an app for this or any pointers?
Thank so much.
Benzle
  • 924
There are plenty of tools to help you backup your system. My personal favorit is rsync
To back up your home folder
rsync -a --delete --quiet /home/User /path/to/HDD
-a
    indicates that files should be archived, meaning that most of their characteristics are preserved
--delete
    means files deleted on the source are to be deleted on the backup as well
It can be done using ssh as well just add -e ssh /home/User user@server:path/to/backup
(if the dedicated HDD is running on a separate server such as mine is)
As a full system backup (which I'm failry certain is what you're looking for)
rsync -aAXv --exclude={"/dev/*","/proc/*","/sys/*","/tmp/*","/run/*","/mnt/*","/media/*","/lost+found"} / /path/to/backup/folder
Using the option -aAXv ensures that all file permissions, ownerships, links, mod times, ACL's and extended attributes are preserved!
I personally have a script to backup my home folder weekly and then zip it and send it to my server, and once a month I will do a full system backup and send it to a different more secure server.
You may also be interested in checking out --parial flag! For completeness though here is the man page https://manpage.me/?q=rsync
j-money
  • 2,516
  • 20
If you would like to do it through the GUI, you can use the application "Backups" from the app menu.
From activities window search for "Backups" and use this application to schedule backing up of all desired folders.
To keep backups small, you can just back up your home folder as this is where all your personal data will be. This can then be restored after a reinstall of the system.
