I KNOW there are other very similar questions here already - but this is subtly different - I have been through all of the similar ones, and none of the advice there solves the issue I am seeing.
It is the logged-in or -out status of the server local user, which differs here (see below) and I don't see why that impacts on what I'm doing.
I have this situation:
  1. Server PC running Lubuntu 16.04
  2. Client PC running Lubuntu 18.04
  3. Want to remote-access Server PC from Client PC, using vino-server for VNC, tunneled through SSH.
Working aspects:
a. I have vino-server installed on the Server and Remmina on the client: these work fine together.
b. I'm familiar with SSH tunnels constructed with the ssh -g - L formulation - that works fine too;
c. If I leave vino-server running and the Server has a keyboard logged in locally, ALL WORKS FINE.
d. But for additional security, I'd like NOT to leave vino-server running all the time, but remote-in initially with a simple remote SSH session, to start it, when I need it. So to test this, I closed vino-server, and logged off as a local user of the Server, and tested remotely. In THIS situation, I can't get the vino-server to start.
Issues:
a. If vino-server is NOT running, but there IS a locally logged on user at the Server PC, if I ssh in to start vino, I get the "could not connect to display" problem;
-- that is solved, by the advice from this question:
How to start a GUI software on a remote Linux PC via SSH
-- essentially, enter export DISPLAY=:0 and then proceed, and all is then good;
b. BUT... if the locally-logged-in user (keyboard) at the server, is logged out, then, the above fix does NOT work. I cannot start vino-server whatever I do.
I've tried various other recommended advice, including more complex forms of the
export DISPLAY=:0
..command, also xhost + , but none of these work.
This seems like it is something simple, because the difference between working and non-working is only that the local user (irrelevant to the process ?) at the server, is logged OUT in the problematic case and logged IN in the working case.
Incidentally: some advice recommended using screen to segregate the session which runs vino-server; I have tried that too: doesn't solve it.
Any and all wisdom on this subject would be appreciated.
Thanks.
PS: Not sure if Lubuntu 18.04 has moved to Wayland, and if that's relevant.. I think it may have.
Thanks to all above who commented on this - I've battled with it for a long stretch, learned a lot, found a lot of people with other incarnations of the same problem, and finally - today - solved it.
Most of the problem appears to be inexpert (if familiar) Linux users (like me) not knowing the innermost concepts of how X windows sessions work with window managers and with VNC servers (of which I've now tested about 4), and what all of those do when working remote with no local user logged in.
On the advice of steedriver above, I tried TightVNC, and then vnc4server, as alternatives to vino: but I got essentially the same problem -inability to get a GUI session to 'wake up' so that a vnc server can deliver a GUI through to a remove VNC client session run over an SSH tunnel.
Net changes I've needed to make to finally solve this, were these:
Firstly, on the advice of a number of people, changed my xstartup configuration, under ~/.vnc as follows:
/home/mikeh/.vnc/xstartup ::
#!/bin/sh
def
export XKL_XMODMAP_DISABLE=1
unset SESSION_MANAGER
unset DBUS_SESSION_BUS_ADDRESS
xrdb $HOME/.Xresources
xsetroot -solid grey
x-terminal-emulator -geometry 80x24+10+10 -ls -title "$VNCDESKTOP Desktop" &
x-window-manager &
# Fix to make GNOME work
/etc/X11/Xsession
Key tweaks there were (a) the addition of the top four lines after #!/bin/sh, and (b) UNcommenting the lines starting x-terminal and x-window-manager
With those changes made, kill & restart the vncserver session (find pid first with ps -ef | grep vnc ).
THEN, remoting in using remmina (through SSH tunnel), I got a "plain grey" window with only an "X" cursor - no 'desktop' in the conventional sense. Took a little more research to realise this is an X window undecorated by a window manager: even though lightdm seemed to be running, not present on the screen the VNC could access.
At this stage, I found RIGHT-click revealed the 'basic' LXDE desktop commands, which include a terminal, 1-of-4 desktop selector, and browser. All work, on 'naked' LXDE (no window manager), but from the terminal, I could then start pcmanfm which worked normally, then vlc which was able to stream video: so clearly all functionality, just no managed window session. So "90% there"..
Futher research this pm, led to advice from here - steeldriver, your advice again:
https://ubuntuforums.org/showthread.php?t=2222849&page=2
Essence of this was your trials leaving to summarised tweaks: which amount to creation of the file ~/.xsession , containing only this:
lxsession -s Lubuntu -e LXDE
Rebooted PC, then
a. remoted simple SSH;
b. started vncserver on the server manually with
    vncserver                        {   -  reports using desktop session 1 ;  }
c. opened the SSH tunnel from client to server (port 5901 far end);
d. remoted in using remmina vnc client --- WORKING FINE, full GUI desktop.
Huge thanks to all gurus whose advice helped me here -- steeldriver, my apologies for not recognising your skill above in comments earlier / thanks for this solution.
For the record -- this was client PC running Lubuntu 18.04 accessing server PC running Lubuntu 16.04.
