i created this question because i cant install phpmyadmin in Ubuntu 18.04 bionic LTS.
i use
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install phpmyadmin
And get "unable to locate package"
I search the package in package.ubuntu.com
And add to sources.list this repository:
mirrors.kernel.org/ubuntu
Now appear a error from depencies.
php-mbstring
php-common
later when try install these, appear:
php7.2-mbstring
php7.2-common
And later:
0.7.2ubuntu-0 (something like this)
How can i install phpmyadmin?
I do this
sudo apt-get update
all packages are updated
0 updated, 0 new will by installed, 0 for delete and 0 not updated
reading package list... done creating three of dependencies reading state information... done E: cannot locate package phpmyadmin
Dev 200
  • 105
Install
sudo add-apt-repository universe
After check
apt search phpmyadmin
Sorting... Done
Full Text Search... Done
adminer/bionic 4.6.2-1 all
  Web-based database administration tool
phpliteadmin/bionic-security,bionic-updates 1.9.7.1-1ubuntu0.1 all
  web-based SQLite database admin tool
phpliteadmin-themes/bionic-security,bionic-updates 1.9.7.1-1ubuntu0.1 all
  web-based SQLite database admin tool - themes
phpmyadmin/bionic 4:4.6.6-5 all
  MySQL web administration tool
After install
sudo apt install phpmyadmin
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
  apache2 apache2-bin apache2-data apache2-utils dbconfig-common dbconfig-mysql javascript-common libapache2-mod-php7.2 libapr1 libaprutil1
  libaprutil1-dbd-sqlite3 libaprutil1-ldap libjs-jquery libjs-sphinxdoc libjs-underscore liblua5.2-0 libsodium23 libzip4 php php-bz2 php-pear
  php-php-gettext php-phpseclib php-tcpdf php-zip php7.2 php7.2-bz2 php7.2-cli php7.2-common php7.2-json php7.2-opcache php7.2-readline php7.2-zip
Suggested packages:
  www-browser apache2-doc apache2-suexec-pristine | apache2-suexec-custom php-libsodium php-mcrypt php-gmp php-imagick
The following NEW packages will be installed:
  phpmyadmin
0 upgraded, 34 newly installed, 0 to remove and 0 not upgraded.
Need to get 18.9 MB of archives.
After this operation, 75.9 MB of additional disk space will be used.
Do you want to continue? [Y/n]
abkrim
  • 362
You can install phpMyAdmin from the default Ubuntu repositories
sudo apt update
sudo apt install phpmyadmin php-mbstring php-gettext
This article is clear enough.
John Joe
  • 268
  • 17
You can install phpMyAdmin from the mirror_kernel for bionic Ubuntu repositories
sudo apt update
sudo apt install phpmyadmin*
if you said nothing appear to do apt search phpmyadmin
please check your repo with right repo in that link.
The solution is as follows (in case the link goes dead [good point, Melebius]):
*You should be able to use any of the listed mirrors by adding a line to your /etc/apt/sources.list like this:
deb http://cz.archive.ubuntu.com/ubuntu bionic main universe
Replacing cz.archive.ubuntu.com/ubuntu with the mirror in question.
You can download the requested file from the pool/universe/p/phpmyadmin/ subdirectory at any of these sites:
https://packages.ubuntu.com/bionic/all/phpmyadmin/download
North America
  • mirrors.kernel.org/ubuntu
  • ftp.osuosl.org/pub/ubuntu
  • lug.mtu.edu/ubuntu
  • ubuntu.mirrors.tds.net/ubuntu
  • ubuntu.secs.oakland.edu
  • mirror.mcs.anl.gov/pub/ubuntu
  • mirrors.cat.pdx.edu/ubuntu
  • ubuntu.cs.utah.edu/ubuntu
  • ftp.ussg.iu.edu/linux/ubuntu
  • mirrors.xmission.com/ubuntu
  • mirrors.cs.wmich.edu/ubuntu
  • gulus.USherbrooke.ca/pub/distro/ubuntu
Asia
  • kr.archive.ubuntu.com/ubuntu
  • th.archive.ubuntu.com/ubuntu
  • mirror.lupaworld.com/ubuntu
  • kambing.vlsm.org/ubuntu
  • ubuntu.mithril-linux.org/archives
  • mirror.in.th/ubuntu
  • mirror.rootguide.org/ubuntu
Africa
  • za.archive.ubuntu.com/ubuntu
Europe
  • cz.archive.ubuntu.com/ubuntu
  • de.archive.ubuntu.com/ubuntu
  • dk.archive.ubuntu.com/ubuntu
  • es.archive.ubuntu.com/ubuntu
  • fr.archive.ubuntu.com/ubuntu
  • ge.archive.ubuntu.com/ubuntu
  • gr.archive.ubuntu.com/ubuntu
  • hr.archive.ubuntu.com/ubuntu
  • mt.archive.ubuntu.com/ubuntu
  • nl.archive.ubuntu.com/ubuntu
  • no.archive.ubuntu.com/ubuntu
  • se.archive.ubuntu.com/ubuntu
  • yu.archive.ubuntu.com/ubuntu
  • nz.archive.ubuntu.com/ubuntu
  • nz2.archive.ubuntu.com/ubuntu
  • ftp.iinet.net.au/pub/ubuntu
  • mirror.optus.net/ubuntu
  • ftp.filearena.net/pub/ubuntu
  • mirror.pacific.net.au/linux/ubuntu
