I have light-coloured wallpaper set and because the date/clock text is all white, it's quite difficult to read for me. Is there any way to either make this text either more visible, either by changing the background of the top bar or by changing the text colour?
For some reason, when I changed my wallpaper away from the default wallpaper, the top bar's background became much lighter. If I could use whatever the default background colour is for these panels that would be perfect.
Screenshot attached here
pomsky
  • 70,557
whjms
  • 75
You may want to increase the opacity of the top bar when no window is maximised. To do that you may use a GNOME shell extension called "Dynamic Panel Transparency".
  1. Install the extension from the link above and reload the page. A settings icon should appear.
  2. Click on the settings icon to open the settings window for the extension.
  3. Go to the "Background" tab and activate "Enable custom opacity".
  4. Set high values (towards 100) for both "Maximized Opacity" and "Unmaximized Opacity".
  5. Re-login.
pomsky
  • 70,557
