I feel like I've literally tried everything with this one.
lsusb
Bus 001 Device 007: ID 0bda:f179 Realtek Semiconductor Corp.
lsusb -t
Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/10p, 480M
 |__ Port 3: Dev 7, If 0, Class=Vendor Specific Class, Driver=, 480M
 |__ Port 4: Dev 45, If 1, Class=CDC Data, Driver=rndis_host, 480M
 |__ Port 4: Dev 45, If 2, Class=Vendor Specific Class, Driver=, 480M
 |__ Port 4: Dev 45, If 0, Class=Wireless, Driver=rndis_host, 480M
 |__ Port 5: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 12M
 |__ Port 5: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 12M
 |__ Port 6: Dev 6, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
 |__ Port 6: Dev 6, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
nmcli device
DEVICE           TYPE      STATE        CONNECTION
br-c90a12778d6e  bridge    connected    br-c90a12778d6e
docker0          bridge    connected    docker0
enp2s0           ethernet  unavailable  --
lo               loopback  unmanaged    --
lshw -class network
*-network
   description: Ethernet interface
   product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:02:00.0
   logical name: enp2s0
   version: 15
   serial: 4c:cc:6a:93:b4:88
   capacity: 1Gbit/s
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
   resources: irq:16 ioport:d000(size=256) memory:df004000-df004fff memory:df000000-df003fff
*-network:0
   physical id: 2
   logical name: br-c90a12778d6e
   serial: 02:42:f0:ad:98:06
   capabilities: ethernet physical
   configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A ip=172.18.0.1 link=no multicast=yes
*-network:1
   physical id: 3
   logical name: docker0
   serial: 02:42:8f:77:a6:ed
   configuration: broadcast=yes driver=bridge driverversion=2.3 firmware=N/A ip=172.17.0.1 link=no multicast=ye
wireless-info:
https://jsfiddle.net/websiter/L9oatjrs/embedded/js/#JavaScript
Using ndiswrapper, I've added the netrtwlanu_Vista driver, which appears to be accepted: (device: present - I tried others as well, which didn't seem to be accepted)...
... but nothing appears in the WiFi Settings and nothing appears in the Additional Drivers tab (I did select "Main server" as source). Also, in various posts and methods I read stuff about blacklisting:
I have no idea what to blacklist and how to check if what's supposed to be blacklisted is.
Before I buy a different WiFi USB dongle, I want to make sure there's nothing I can do about installing this one (I tested it and works on Windows 10).
Also, is there a list of USB WiFi devices that work on Ubuntu 18?
I'm far from being familiar with Ubuntu, please provide clear instructions. If more info is needed, let me know.
tao
  • 141
