KVM is required to run this AVD. /dev/kvm device: permission denied.
Grant current user access to /dev/kvm
I had this mistake with Android Studio 3.0.1 on Ubuntu 18.04 when I run the emulator. You can try this answer. To add the user username to the kvm group, you could use:
sudo apt install qemu-kvm
sudo adduser $USER kvm
In my case it worked, albeit with a re-login required after the whole process.
first of all paste in your terminal
kvm-ok
if you got dev/kvm not exist, KVM acceleration can not be used , your CPU does not support virtualization, or it is disabled in the bios. Go into your bios and see if you can find a setting to enable it.
