I am a newbie with Ubuntu and running a dual boot with windows 10 and ubuntu 18, i tried installing hibernate by doing
"apt-get install hibernate"
but when i try
sudo hibernate
the screen goes off for a few seconds then i get the following error
hibernate:Warning: Tuxonice binary signature file not found.
I can only say that this warning doesn't necessary mean that hibernation will not succeed. For me hibernation works even though the warning is displayed. Why it doesn't work in Your case may be a matter of other issues. For example, if I'm not wrong, it may be connected with size of Your SWAP partition (if nothing changed in the meantime, it is recommended to be a size of You RAM memory I believe) or GRUB configuration (boot options).
For the start I would recommend trying some other programs like pm-hibernate. If I were You, I would also check out this question: Hibernation in 18.04 (which seems to contain solution in the answer, hmm...) or this one: How can I hibernate on Ubuntu 16.04? and try to search for more if needed.
And, by the way, I believe it does not really have much to do with dual booting.
kcpr
  • 1,472
This is more of a clarifying comment than an answer. The text of the error is arguably a bug in of itself:
Here the programmer has attempted to warn users that a file seems to missing. But the programmer has left out an essential piece of data, specifically the name of that file.
The program itself must know, so it's not like the error message couldn't say something like:
hibernate:Warning: Tuxonice binary signature file "/foo/bar/baz123" not found.
...which would enable the user to make progress by checking if the file baz123 existed, and was in the correct location, had the correct permissions, and had reasonable contents.
Note: After running hibernate, (which worked, Linux Mint v20.2), I encountered this vague error message today, three years after the Q. was first posted.
agc
  • 563
