When using ABAQUS 6.14 (but also ABAQUS 2018) on ubuntu 18.04 everything seems to work fine except the termination of the standard process (the process started when performing an implicit analysis -- if you are not familiar with this it doesn't matter).
The analysis indeed works as one can also see in a log file (the .sta file, for those who are familiar with abaqus) the message THE ANALYSIS HAS COMPLETED SUCCESSFULLY. The output database contains the analysis results. However, after the analysis has been completed, the process standard remains in a sleeping status using 0% CPU and keeping the same amount of RAM as when it was running.
From strace I get:
[pid 23191] close(8) = 0
[pid 23185] <... select resumed> ) = 0 (Timeout)
[pid 23185] select(0, NULL, NULL, NULL, {tv_sec=0, tv_usec=50000} <unfinished ...>
[pid 23193] <... select resumed> ) = 0 (Timeout)
[pid 23193] futex(0x7f3acd917db0, FUTEX_WAKE_PRIVATE, 1 <unfinished ...>
[pid 23191] futex(0x7f3acd917db0, FUTEX_WAIT_PRIVATE, 2, NULL <unfinished ...>
[pid 23193] <... futex resumed> ) = 0
[pid 23191] <... futex resumed> ) = -1 EAGAIN (Resource temporarily unavailable)
[pid 23191] futex(0x7f3acd917db0, FUTEX_WAKE_PRIVATE, 1) = 0
[pid 23193] select(7, [4 5 6], NULL, NULL, {tv_sec=0, tv_usec=20000} <unfinished ...>
[pid 23191] munmap(0x7f3ab130b000, 327680) = 0
[pid 23191] munmap(0x7f3ab136b000, 1114112) = 0
[pid 23191] munmap(0x7f3ab16db000, 1114112) = 0
[pid 23191] munmap(0x7f3ab0fbb000, 1114112) = 0
[pid 23191] munmap(0x7f3ab0ddb000, 1114112) = 0
[pid 23191] munmap(0x7f3ab0a0b000, 1114112) = 0
[pid 23191] munmap(0x7f3ab03fb000, 1114112) = 0
[pid 23191] munmap(0x7f3ab050b000, 1114112) = 0
[pid 23191] munmap(0x7f3ab00cb000, 1114112) = 0
[pid 23191] munmap(0x7f3ab02eb000, 1114112) = 0
[pid 23191] munmap(0x7f3ab14eb000, 1114112) = 0
[pid 23191] futex(0x7f3ab8a5dd44, FUTEX_WAIT_PRIVATE, 8, NULL) = -1 EAGAIN (Resource temporarily unavailable)
[pid 23191] futex(0x7f3ab8a5dd44, FUTEX_WAIT_PRIVATE, 12, NULL <unfinished ...>
[pid 23193] select(7, [4 5 6], NULL, NULL, {tv_sec=0, tv_usec=20000}) = 0 (Timeout)
[pid 23185] select(10, [5 6 8 9], NULL, NULL, {tv_sec=0, tv_usec=20000} <unfinished ...>
Like if the two processes were in a deadlock state. Moreover, the commands
pid -p 7002
and
pid -p 7010
do give an empty output. The dirs /proc/7002 and /proc/7010 do not exist.
The only abaqus-related processes executing are
david 6995 0.0 0.1 295428 51388 pts/0 S 17:00 0:00 /opt/abaqus/6.14-1/code/bin/python /opt/abaqus/6.14-1
david 6998 0.0 0.2 368744 97948 pts/0 S 17:00 0:00 /opt/abaqus/6.14-1/code/bin/python std_inst.com
david 7001 0.1 0.0 122076 20096 pts/0 Sl 17:00 0:03 /opt/abaqus/6.14-1/code/bin/eliT_DriverLM -job std_in
david 7008 0.4 0.5 735812 185364 pts/0 Sl 17:00 0:07 /opt/abaqus/6.14-1/code/bin/standard -standard -acade
On ubuntu 16.04 the exact same version works like a charm. Here the same strace on ubuntu 16.04 (with the same kernel version as my 18.04, i.e. 4.15.0-29):
3890 close(8) = 0
3892 <... select resumed> ) = 0 (Timeout)
3892 futex(0x7f29e43e1db0, FUTEX_WAIT_PRIVATE, 2, NULL <unfinished ...>
3890 futex(0x7f29e43e1db0, FUTEX_WAKE_PRIVATE, 1) = 0
3892 <... futex resumed> ) = -1 EAGAIN (Resource temporarily unavailable)
3892 futex(0x7f29e43e1db0, FUTEX_WAKE_PRIVATE, 1 <unfinished ...>
3890 futex(0x7f29e43e1db0, FUTEX_WAIT_PRIVATE, 2, NULL <unfinished ...>
3892 <... futex resumed> ) = 0
3890 <... futex resumed> ) = -1 EAGAIN (Resource temporarily unavailable)
3892 select(7, [4 5 6], NULL, NULL, {0, 20000} <unfinished ...>
3890 munmap(0x7f29c7adb000, 327680) = 0
3890 munmap(0x7f29c7b3b000, 1114112) = 0
3890 munmap(0x7f29c7eab000, 1114112) = 0
3890 munmap(0x7f29c778b000, 1114112) = 0
3890 munmap(0x7f29c75ab000, 1114112) = 0
3890 munmap(0x7f29c71db000, 1114112) = 0
3890 munmap(0x7f29c6bcb000, 1114112) = 0
3890 munmap(0x7f29c6cdb000, 1114112) = 0
3890 munmap(0x7f29c689b000, 1114112) = 0
3890 munmap(0x7f29c6abb000, 1114112) = 0
3890 munmap(0x7f29c7cbb000, 1114112) = 0
3890 exit_group(0) = ?
3891 +++ exited with 0 +++
3893 +++ exited with 0 +++
3892 +++ exited with 0 +++
3890 +++ exited with 0 +++
3880 <... wait4 resumed> [{WIFEXITED(s) && WEXITSTATUS(s) == 0}], 0, NULL) = 3890
3880 --- SIGCHLD {si_signo=SIGCHLD, si_code=CLD_EXITED, si_pid=3890, si_uid=1000, si_status=0, si_utime=107, si_stime=7} ---
Has someone a good idea how to solve this? Or in which direction should I investigate further.
