I have this problem: I want install these packages: nvidia-390 (driver) nvidia-libopencl1-390 nvidia-opencl-icd-390 on Ubuntu Server 18.04.
$ uname -r
4.15.0-29-generic
I have installed nvidia-390, further when installing nvidia-libopencl1-390 I have the following errors:
# apt install nvidia-libopencl1-390
Reading Package Lists ... Done
Building a Dependency Tree
Reading status information ... Done
Some packages can not be installed. Perhaps you are asking for the impossible,
or use an unstable version of the distribution, where you requested
packages are not yet created or have been removed from Incoming.
The following information may help you:
Packages with unsatisfied dependencies:
  nvidia-libopencl1-390: Depends: nvidia-compute-390 but it can not be installed
E: It is impossible to fix errors, you have held broken packages.
The same is true with nvidia-opencl-isd-390.
Such errors are observed on the versions 387,390. Deleted all the packages of the nvidia-*, then installed the 384 version, but 387, 390 also gave an error.
Version 384 packages were installed, entered the command nvidia-xconfig, reboot. After that the driver is working, but opencl is not detected by the programs. They say that it is not installed by opencl.
How to fix 384 or fix and install version nvidia's 390 packages?
NEW
Thank you, I did so. First I checked what I needed ubuntu-drivers device
ubuntu-drivers devices
== /sys/devices/pci0000:00/0000:00:1d.1/0000:07:00.0/0000:08:03.0/0000:0b:00.0 == modalias : pci:v000010DEd00001C03sv00001462sd00003281bc03sc00i00 vendor : NVIDIA Corporation model : GP106 [GeForce GTX 1060 6GB] driver : nvidia-driver-390 - third-party free driver : nvidia-driver-396 - third-party free recommended driver : xserver-xorg-video-nouveau - distro free builtin
396 is recommended, but there is no opencl 396.
I am using the nvidia-driver-390 driver version 390.48 in 18.04 which was installed with the following commands:
sudo ubuntu-drivers install
sudo reboot
The ubuntu-drivers install option installs drivers that are appropriate for automatic installation including their dependencies, and the Nvidia driver will also be updated automatically when an update is available. This command will not install nvidia-libopencl1-390 or libnvidia-libopencl1-390 which you don't need. Instead if you need opencl, install it separately with the following command:
sudo apt install nvidia-opencl-dev
Before you run ubuntu-drivers install you must first uninstall all the nvidia-* packages that are currently installed as you did before and then reboot with sudo reboot. After you run sudo ubuntu-drivers install && sudo apt install nvidia-opencl-dev you must reboot as usual to enable the changes in graphics drivers with sudo reboot
karel
  • 122,292
  • 133
  • 301
  • 332
