I'm trying to get my glassfish server to run as soon as I start the computer, but I run into the following error:
When I try to execute the "update-rc.d" command, it complains that it does not find the command.
I´m using Ubuntu Server (version 18.04.1). What do I have to do to make this command work? Will there be a substitute command for this?
TwoDent
  • 109
you have a syntax error in your command - update
sudo update-rc.d glassfish defaults 90 10
Edit :In then image you provided you issued the command sudo uptade-rc.d glassfish defaults 90 10 which results in the error you received due to the fact that no such executable exists.
Elder Geek
  • 36,752
abu_bua
  • 11,313
See Panther's comment above.. I almost missed it:
That does not work with systemd see digitalocean.com/community/tutorials/… – Panther
This was helpful: https://askubuntu.com/a/1147142/795299
But if you came here for a GCP GCE VM see this: https://stackoverflow.com/questions/30766912/how-do-i-add-a-startup-script-to-an-existing-vm-from-the-developer-console/30766913
alchemy
  • 850
