On Windows 10 I get ~90Mbps download and upload, while on Ubuntu 16.04 I get ~9Mbps download and ~1Mbps upload.
Why is there such a big difference and what do I do to speed it up? The two OS are set up on the same hardware with dualboot.
I am using a wireless network adapter TP-LINK TL-WN821N made by belkin and since it is working fine on Windows I suspect its some driver issue or something.
--- Output of lsusb ---
Bus 002 Device 004: ID 046d:c31c Logitech, Inc. Keyboard K120
Bus 002 Device 003: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 005: ID 2357:0107
Bus 001 Device 003: ID 03f0:e207 Hewlett-Packard
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
--- Output of lsmod | grep rtl ---
rtl8xxxu 122880 0
mac80211 778240 1 rtl8xxxu
--- Content of /etc/modprobe.d/ ---
alsa-base.conf
amd64-microcode-blacklist.conf
blacklist-ath_pci.conf
blacklist.conf
blacklist-firewire.conf
blacklist-framebuffer.conf
blacklist-modem.conf
blacklist-oss.conf
blacklist-rare-network.conf
blacklist-watchdog.conf
dkms.conf
fbdev-blacklist.conf
intel-microcode-blacklist.conf
iwlwifi.conf
mlx4.conf
nvidia-384_hybrid.conf
nvidia-graphics-drivers.conf
--- Content of /etc/modprobe.d/iwlwifi.conf ---
# /etc/modprobe.d/iwlwifi.conf
# iwlwifi will dyamically load either iwldvm or iwlmvm depending on the
# microcode file installed on the system. When removing iwlwifi, first
# remove the iwl?vm module and then iwlwifi.
options iwlwifi 11n_disable=1 led_mode=1 swcrypto=1
remove iwlwifi \
(/sbin/lsmod | grep -o -e ^iwlmvm -e ^iwldvm -e ^iwlwifi | xargs /sbin/rmmod) \
&& /sbin/modprobe -r mac80211
EDIT: MTU of the adapter:
wlx503eaa683858
MTU:1500
EDIT 1:
1?: [LOCALHOST] pmtu 1500
1: 192.168.0.1 13.435ms reached
1: 192.168.0.1 13.473ms reached
Resume: pmtu 1500 hops 1 back 1
EDIT 2: I upgraded from 16.04 to 18.04.1 today, but the issue is still present. My WiFi adapter is listed as disconnected in nmcli after restart and I have to remove/add it again to the USB so it can properly work.
