It's as the Title says, Just downloaded the ISO for Ubuntu 18.04.1 transferred it to a USB stick and installed from there. After install asks you to restart the machine and hard drive does a few accesses and then just hangs with a black screen.
Had the same Issue after installing Ubuntu 18.04 it ran fine and then allowing it to auto update. Tried grub menu options repair etc.
I'm a bit miffed as I was hoping to move away from Windows 10. Should I just stick with 18.04 and disable all updates?
pomsky
  • 70,557
Maybe you should try to boot with acpi_osi=! acpi_osi='Linux' or acpi=off or nomodeset in kernel parametets? If it boots with the first two something is wrong with your ACPI tables.
