I am trying to upgrade from Ubuntu 16.10 to Ubuntu 18.04 and getting this error everytime:
An upgrade from 'yakkety' to 'bionic' is not supported with this tool.
How do I resolve this?
I used this.
Before you will upgrade to the 17.10 and the to 18.04.
When you login you will have both unity and gnome available but if I remember exactly you can' t use unity. With the first upgrade some things (for example files) in the launcher bar will disappear and also some options in the top panel.
If you search here you will find how restore the top panel options (and add programs to the launcher bar is easy).
But don't do it because after the second upgrade you will lost them again. Some apps (for example Open Arena) don't work with 17.10 and 18.04.
I prefer unity instead of gnome and you can install it using sudo apt update and sudo apt install ubuntu-unity-desktop.
I suggest to install it using the iso, using the same username and password without formatting the home partition you won' t lose that partition. Made some researches to be sure to not lost something important for you.
After the terminal update i reinstalled Ubuntu 16.04.
Vogel612
  • 119
Scorpion
  • 384
  • 15
