I am writing a small script to upload the files to remote ssh server and on the remote ssh server I will have almost 2 TB of Space available.
I need to check within the shell script if the Space is around 1.5 TB full than sleep the script and **start the script again** once its goes back it goes back to 1TB
here is my part of the code which needs to run the logic for checking the directory size and then put it into the if else statements
SIZE="$(ssh archiveupload@REMOTESERVER-IP "du -s")"
LIMIT="1.5TB"
if [ $SIZE -gt $LIMIT ];
then
  sleep 4h
elif
 continue ;
fi
UPDATE SCRIPT:
if [ ! -f /home/user/Tupload/upload-lock ]; then
    touch /home/user/Tupload/upload-lock
    ###Define the File in unix style#############
    filename="/home/user/Tupload/20186.txt"
    ####starting of the while loop.###########
    LIMIT='1500000000'
    while read line;
    do
        name="${line%$'\r'}"
        SIZE="$(ssh -n USER@REMOTEIP"df /var/www/Upload/" | awk 'NR > 1 {print $4; exit}')"
        if [[ $SIZE -gt $LIMIT ]]
        then
            YEAR=$(echo $name | cut -c 1-4)   #####define the Year from the read line ####
            MONTH=$(echo $name | cut -c 5-6)  #####Define the Month from the read line####
            DAY=$(echo $name | cut -c 7-8)  #####Define the DAY from the read line####
            YM=${YEAR}-${MONTH} ####define the Year and Month######
            april="2017-04"
            may="2017-05"
            june="2017-06"
            march="2017-03"
            ######if else statement ######
            if [ "$april" = "$YM"  ]; then
                cd /mnt/smxfxml/$YEAR/April/
            elif [ "$may" = "$YM"  ]; then
                cd /mnt/smxfxml/$YEAR/May/
            elif [ "$june" = "$YM"  ]; then
                cd /mnt/smxfxml/$YEAR/June/
            elif [ "$march" = "$YM"  ]; then
                cd /mnt/smxfxml/$YEAR/March/
            else
                cd /mnt/smxfxml/$YEAR/$YM/
            fi
            ssh USER@REMOTEIP"mkdir $YEAR/$MONTH/$DAY/$name/" < /dev/null
            scp $name.mxf USER@REMOTEIP:$YEAR/$MONTH/$DAY/$name/
            cd /mnt/smxfxml/XML/$YEAR/$YM/
            scp $name.xml USER@REMOTEIP:$YEAR/$MONTH/$DAY/$name/
        else
            echo 'Not enough space.'; sleep 4h
        fi
    done <"$filename"
    rm -rf /home/user/Tupload/upload-lock
    exit 0
else
    sleep 0
fi
exit 0
danzel
  • 6,533
kunal
  • 442
First I wold suggest you to use the command df to get the free space. Also you should provide a system path (for example /) or device name (for example /dev/sda1) to make the things simple. The output of the command df / executed on my VPS looks like:
$ ssh -n user@host "df /"
Filesystem     1K-blocks    Used Available Use% Mounted on
/dev/vda1       25671932 8335064  16009768  35% /
We need only the available space so we can filter the output by the help of awk (for example):
$ ssh -n user@host "df /" | awk 'NR > 1 {print $4; exit}'
16009768
Second use the same units as the output of the above command (1K-blocks) for the value of the variable $LIMIT: 1.5 TB = 1500000000 KB.
Third put the main logic into a function that will call itself recursively again and again after the sleep command. In addition the places of sleep and continue should be inverted, I think :)
According to the above the script could be something as this:
#!/bin/bash -e
LIMIT='1500000000'
# define the function
main() {
    SIZE="$(ssh -n user@host "df /" | awk 'NR > 1 {print $4; exit}')"
    then
        echo 'continue'
    else
        # call the function
        main
    fi
# initial call of the function
main
According to the @danzel's comment instead of recursion we can use infinite while loop:
#!/bin/bash -e
LIMIT='1500000000'
while true
do
    then
        # remove the exit command if you do not want to interupt the loop
        echo 'continue'; exit
    else
    fi
done
pa4080
  • 30,621
Thanks to pa4080 for the "free space" one liner.
Now that you shared your script:
It's going to be a little bit more difficult because we cannot use continue inside the while read line loop without skipping lines.
You want to pause the script when there is no more than 0.5TB free, and resume when there is at least 1TB free.
To keep the script short and human readable, define a function that tells you if there is enough space on the server and takes the minimum size as parameter:
enough_space () {
    local limit=$1
    free_space="$(ssh -n user@host "df /" | awk 'NR > 1 {print $4; exit}')"
    [ $free_space -ge $limit ]
...and either sleep while not enough space :
while ! enough_space $limit; do
    sleep 4h
done
...or sleep until enough space :
until enough_space $limit; do
    sleep 4h
done
Incorporating this in your script
Put this at the beginning of your script:
pause_limit='500000000'    # 0.5TB free space
resume_limit='1000000000'  # 1.0TB free space
enough_space () {
    local limit=$1
We'll introduce an "infinite" while loop inside the existing while loop. This enables us to retry the same file again when there wasn't enough free space the first time. Also, assigning the variables is not dependent on the server's free space, so it should be kept outside of the if statement (and the inner while loop).
while read line; do
#### this can all be done before checking the server's free space
#    name="${line%$'\r'}"
#    YEAR=$(echo $name | cut -c 1-4)
    ######if else statements ######
#    if [ "$april" = "$YM"  ]; then
#    fi
    while true; do
        if enough_space $pause_limit;
        then
            break
        else
            until enough_space $resume_limit; do
                sleep 4h
            done
        fi
    done
done <"$filename"
The "infinite" while loop will either run once (if there is enough free space on the server) or twice (if there is enough free space again).
Additional notes
If you want to run your copy routine over and over again indefinitely, use an infinite while loop (while true; do...). Don't do recursive calls (calling the script within the script or the function within the function), because that will increase the call stack size and your script will crash sooner or later.
This is, of course, only one of many ways to achieve the same thing. One downside of this approach is that whenever the free space falls below 0.5TB or exceeds 1.0TB, there will be one unnecessary call to enough_space.
If I misinterpreted your question, please tell me so I can adapt my answer.
danzel
  • 6,533
