I have received a MSI GS65 8RE-052FR Stealth Thin laptop that comes with Windows 10 enterprise pre-installed (I was previously working with Windows 7). I am trying to install a dual-boot with Xubuntu 18.04.
I have already partitioned the hard drive to make some space for Xubuntu. Next step is trying Xubuntu from a Live USB.
I have a USB drive for this with Multisystem and a collection of Linux variants. I have tested the USB drives on another laptop (a DELL with also Windows 10). I can boot the latest version of Xubuntu (18.04) from the USB drive through both Legacy BIOS or UEFI on this laptop.
Note for those who own the same laptop and search how to access the boot media menu at startup : on this computer, it's with F11, not F12 or F2. Similarly, to access the UEFI menu at computer startup, press DEL.
I have gone through several problems with the MSI laptop. First of them : to find how the hell you access the UEFI menu from the bloody Windows 10 interface ! (Finally found it : restart while pressing down Shift to access some menu which I am not even sure if it's part of Windows or UEFI).
Then I tried disabling the UEFI to switch to Legacy BIOS and disable Fast Boot. It simply ended up messing everything completely : I could not start neither Windows, nor from a Live USB, nor access again UEFI (I need to boot Windows first !). Fortunately, I could reset UEFI by pressing down the power button for 20 seconds.
I have learned in the meantime that the latest versions of Ubuntu can boot from UEFI so decided I would give it a try since Legacy BIOS had not worked. I have accessed again UEFI and checked : Secure Boot is not active ; I have disabled Fast Boot ; the boot mode is UEFI.
Results : - I can still boot Windows (good). - I can still choose the boot media at startup (good). - Then I can choose Xubuntu 18.04but it ends up being completely stuck during the OS boot. - But if I choose Xubuntu 16.04, it works !
What the hell ! I can only boot / install older versions of Ubuntu ?!
Here is the result of Boot-Info : https://pastebin.com/gG0d2mCV but I don't believe it has anything to do with it.
I have also tried this with Linux Mint with the same result.
