After rebooting my Ubuntu 16.04 on virtual machine, I discovered that /dev/sda2 is no longer available.
Here are my outputs from df and sudo fdisk -l:
df -h:
Filesystem      Size  Used Avail Use% Mounted on
udev            121G     0  121G   0% /dev
tmpfs            25G   13M   25G   1% /run
/dev/sda5       769G  423G  307G  58% /
tmpfs           121G   25M  121G   1% /dev/shm
tmpfs           5.0M     0  5.0M   0% /run/lock
tmpfs           121G     0  121G   0% /sys/fs/cgroup
tmpfs            25G   56K   25G   1% /run/user/100
sudo fdisk -l:
Device          Start        End    Sectors   Size Type
/dev/sda1        2048    1050623    1048576   512M EFI System
/dev/sda2     1050624 4621869402 4620818779   2.2T Linux filesystem
/dev/sda3  6258690048 6291453951   32763904  15.6G Linux swap
/dev/sda4  4621871104 4621873151       2048     1M BIOS boot
/dev/sda5  4621873152 6258690047 1636816896 780.5G Linux filesystem
How can I remount the /dev/sda2? Thanks
Rob John
  • 343
