The .bash_profile file has the alias below.
~# cat .bash_profile
# other commands
alias btcblock="echo $(bitcoin-cli getblockcount 2>&1)/$(wget -O - http://blockchain.info/q/getblockcount 2>/dev/null)"
But if I run the command and shortly thereafter the alias, the results showed are different, as below:
~# echo $(bitcoin-cli getblockcount 2>&1)/$(wget -O - http://blockchain.info/q/getblockcount 2>/dev/null)
503967/534428
~# btcblock
503839/534428
It's like the results of alias is always outdated. Any idea why it's happening ?
le0
  • 113
In the command alias btcblock="echo $(...)/$(...)", the two $()s are executed and interpolated when the alias is defined, because this is how "..." quoting works.
You probably wanted to write alias btcblock='echo $(...)/$(...)', with ' (single quotes) instead of " (double quotes).
AlexP
  • 10,435
