I have a reasonably new 64GB memory stick that I have used for creating bootable media for things like Ubuntu and Cloudready. I now wish to 'empty' it and reclaim the full 64GB but I am having problems.
I've looked at several threads but have not been able to find anything that works.
I thought that using format or initialize would free up things but this has not been the case.
The sudo fdisk -l output is ...
Disk /dev/loop12: 310.8 MiB, 325902336 bytes, 636528 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk /dev/sdb: 14.4 GiB, 15472047104 bytes, 30218842 sectors
I think the /dev/loop12 is what remains from a Cloudready boot set up, the /dev/sdb is the result of using Gparted etc. during attempts to reset the whole drive back to a single partition.
Can anyone please supply the terminal commands necessary to wipe everything and set up the drive as FAT32 or NTFS, etc.
P.S.: This is similar terminal output produced while a working 32 gig USB drive containing Cloudready is inserted instead of the one I'm having problems with.
This is the output for the hard drive + good 32GB drive
/* INTERNAL SDD
$ sudo fdisk -l
[sudo] password for zoom:
Disk /dev/loop2: 4.9 MiB, 5152768 bytes, 10064 sectors
Disk /dev/loop3: 86.9 MiB, 91099136 bytes, 177928 sectors
Disk /dev/loop4: 371.7 MiB, 389734400 bytes, 761200 sectors
Disk /dev/sda: 223.6 GiB, 240057409536 bytes, 468862128 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: gpt
Disk identifier: A2DDEF5A-F5B3-4A4F-887F-443D015D386F
Device         Start       End   Sectors  Size Type
/dev/sda1       2048    923647    921600  450M Windows recovery environment
/dev/sda2     923648   1128447    204800  100M EFI System
/dev/sda3    1128448   1161215     32768   16M Microsoft reserved
/dev/sda4    1161216 288422327 287261112  137G Microsoft basic data
/dev/sda5  288423936 290449407   2025472  989M Windows recovery environment
/dev/sda6  290451456 452415487 161964032 77.2G Linux filesystem
/dev/sda7  452415488 468860927  16445440  7.9G Linux swap
/* REMOVABLE DRIVE
Disk /dev/sdb: 28.7 GiB, 30752000000 bytes, 60062500 sectors
Disklabel type: gpt
Disk identifier: DE03DF63-300E-4548-B0BB-82F655FA0C3D
/dev/sdb1       64       64       1  512B ChromeOS reserved
/dev/sdb2       65       65       1  512B ChromeOS reserved
/dev/sdb3       66       66       1  512B ChromeOS reserved
/dev/sdb4       67       67       1  512B ChromeOS reserved
/dev/sdb5       68       68       1  512B ChromeOS reserved
/dev/sdb6       69       69       1  512B ChromeOS reserved
/dev/sdb7       70       70       1  512B ChromeOS reserved
/dev/sdb8       71       71       1  512B ChromeOS reserved
/dev/sdb9       72       72       1  512B ChromeOS reserved
/dev/sdb10      73       73       1  512B ChromeOS reserved
/dev/sdb11      74       74       1  512B ChromeOS reserved
/dev/sdb12      75       75       1  512B ChromeOS reserved
/dev/sdb13      76       76       1  512B ChromeOS reserved
/dev/sdb14      77       77       1  512B ChromeOS reserved
/dev/sdb15      78       78       1  512B ChromeOS reserved
/dev/sdb16 8626242 13164609 4538368  2.2G Microsoft basic data
/dev/sdb17   20546    53313   32768   16M ChromeOS kernel
/dev/sdb18 2383938  8626241 6242304    3G ChromeOS root fs
/dev/sdb19   53314    86081   32768   16M ChromeOS kernel
/dev/sdb20 2379842  2383937    4096    2M ChromeOS root fs
/dev/sdb21   16514    16514       1  512B ChromeOS kernel
/dev/sdb22   16515    16515       1  512B ChromeOS root fs
/dev/sdb23   86082  2183233 2097152    1G Microsoft basic data
/dev/sdb24   16516    16516       1  512B ChromeOS reserved
/dev/sdb25   16517    16517       1  512B ChromeOS reserved
/dev/sdb26     130    16513   16384    8M unknown
/dev/sdb27 2314306  2379841   65536   32M EFI System
Partition table entries are not in disk order.
karel
  • 122,292
  • 133
  • 301
  • 332
