-3
I followed these steps to download and install scala but faced some issues.
Install Scala
  1. First download scala-2.12.1.tgz from the scala site
  2. Then run the following commands in the terminal
    sudo mkdir /usr/local/src/scala
    sudo tar -xvf sscala-2.12.1 .tgz -C /usr/local/src/scala/nano .bashrc
    after that add this variable at the end of opened .bashrc file
    export SCALA_HOME=/usr/local/src/scala/scala-2.12.1
    export PATH=$SCALA_HOME/bin:$PATH
    . .bashrc
When I wrote the 2nd command in terminal it showed
tar: usr/local/src/scala/nano.bashrc: cannot open: no such file or directory
tar: Error is not recoverable: existing now.
I need help to resolve this issue.
Zanna
  • 72,312
You got the following error:
because you didn't extract the contents of scala-2.12.1.tgz because of a typo error. Instead of:
The correct commands should be:
sudo mkdir /usr/local/src/scala/
sudo tar -xvf scala-2.12.1.tgz -C /usr/local/src/scala/
nano .bashrc
These commands will solve the immediate problem in the question, however it should be noted that according to the official Scala website the most popular way to get Scala is either using Scala through sbt, the Scala build tool, or to use Scala through an IDE. Using Scala through IntelliJ IDE is recommended for beginners who are not familiar with the command line. The free intellij-idea-community snap package can be installed in all currently supported versions of Ubuntu with the following commands:
sudo snap install intellij-idea-community --classic
In Ubuntu 16.04 and 18.04 the package name of the required Java 8 JDK in the default Ubuntu repositories is openjdk-8-jdk and it can be installed by the following command:
sudo apt install openjdk-8-jdk
Run the following commands to export the path to SCALA_HOME to the PATH variable.
export SCALA_HOME="/usr/local/src/scala/scala-2.12.1"
source ~/.bashrc
karel
  • 122,292
  • 133
  • 301
  • 332
