23
When trying to enable "Screen Sharing" under the "Sharing" section of the system settings I can click on the "ON/OFF" slider but it will not stay set to "ON". I can set the "Sharing" slider to "ON" and the "Remote Login" slider to "ON" but not the "Screen Sharing" one. Am I missing something?
Running Ubuntu 18.04.1 LTS and have attempted this both on GNOME on xorg and GNOME Flashback
karel
  • 122,292
  • 133
  • 301
  • 332
6 Answers6
This happened to me, here is how I corrected it.
My network showed "wired-unmanaged"; to correct this, I had to do the following:
Note: If you're interested in a set of commands to copy/paste into your terminal, I'd encourage you to review these instructions first, before running the commands listed at the end of this answer.
  • cd /etc/NetworkManager
  • save NetworkManager.conf to NetworkManager.orig (as a backup)
  • sudo vi NetworkManager.conf
    Change managed=false to managed=true
    New file looks like this:
    [main]
        plugins=ifupdown,keyfile
    [ifupdown]
        managed=true
    [device]
        wifi.scan-rand-mac-address=no
  • sudo service network-manager restart
  • cd /etc/netplan
  • sudo vi 50-cloud-init.yaml
    Add this line just below network:
    renderer: NetworkManager
    New file looks similar to this (ensure the renderer line is indented as shown):
    network:
        ethernets:
            enp3s0:
                addresses: []
                dhcp4: true
    version: 2
  • save
  • sudo netplan apply
  • I had then to restart the computer for this to be effective.
  • After restart the network will now show "wired-connected"
  • Then you can go to Settings » Sharing » Screen Sharing
    • You should now be able to toggle Screen Sharing to ON
    • Under Networks (bottom of dialog), toggle those ON as well
Commands
If all you're looking for is some terminal commands, and you haven't made any manual changes to the files mentioned in the instructions above, running the commands below should take care of the file modifications:
sudo cp NetworkManager.conf NetworkManager.orig
# Change NetworkManager.conf: 'managed=false' to 'managed=true'
sudo sed -i 's/managed=false/managed=true/g' NetworkManager.conf
cd /etc/netplan
# Ensure networks are managed by NetworkManager
# Whitespace in this command is important!
sudo sed -i '/^network:/a \    renderer: NetworkManager' 50-cloud-init.yaml
sudo netplan apply
# Restart your machine, or uncomment one of the lines below:
#sudo shutdown -r now
#gnome-session-quit --reboot
After you run these commands, refer to the final step above to enable screen sharing.
Jay
  • 71
Use x0vncserver as explained in how to start a vnc server for the actual display.
sudo apt-get install tigervnc-scraping-server
Then set a password
vncpasswd
Then start the server with
 x0vncserver -passwordfile ~/.vnc/passwd -display :0
@Jay's answer is good. The problem is caused if one disables network manager and instead use networkd in netplan. To continue to use networkd, I simply added:
/usr/lib/vino/vino-server
To my Startup Applications.
I assume he added the ethernet and interface lines. You have to make sure the interface for your computer is used. His was enp3s0
You can run "ip a" and it will list your network devices. Will look like this:
:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
   valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: ens2f0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:1e:67:79:08:5c brd ff:ff:ff:ff:ff:ff
inet 131.192.176.162/24 brd 131.192.176.255 scope global dynamic noprefixroute ens2f0
   valid_lft 680301sec preferred_lft 680301sec
inet6 fe80::21e:67ff:fe79:85c/64 scope link
3: ens2f1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:1e:67:79:08:5d brd ff:ff:ff:ff:ff:ff
Note in this there are 2 interfaces: ens2f0 and ens2f1
I realize you asked this question a while back. You should be able to get screen share working.
For me, I couldn't enable screen sharing, because I was running in "Wayland" (as that was the only desktop I could use). Well, Wayland doesn't support the screen sharing option. I fixed this issue by switching to the original XOrg "Ubuntu" desktop. In order to get that to work, however, there was a battle...
Check out my post on this other thread: Ubuntu 18.04 won't show desktop after login
BuvinJ
  • 303
I had this problem from two new installs of 18.04. The fix that worked was running code below in a terminal and then rebooting:
sudo apt install vino
Answer was from here: Cannot turn on sharing on ubuntu 18.04
Tim W
