I have a Full install USB flash drive.
I want the drive to work on most computers.
Is it OK to install Nvidia graphics drivers to suit my home computer.
I did some testing and the result was quite interesting.
I installed a basic Lubuntu 18.04.1 LTS 64-bit system in a Sandisk Extreme 16 GB in BIOS mode in an old computer from 2008 with built-in nvidia graphics. This computer has an M2N-VM DV motherboard, an Athlon-64-X2-4400+ CPU and a GeForce 7050 PV / nForce 630a graphics chip.
I know that in Ubuntu 12.04 LTS it needed nvidia proprietary graphics to work well, and that in recent versions it works well with the free linux driver 'nouveau'.
I tested the oldest two available proprietary drivers in 18.04.1 LTS as well as the newest available proprietary driver. None of them worked but the system defaulted to a VGA screen, 640x480.
So I stayed with the newest driver,
apt-cache policy nvidia-384
nvidia-384:
Installerad: 390.48-0ubuntu3
Kandidat: 390.48-0ubuntu3
Versionstabell:
*** 390.48-0ubuntu3 500
500 http://se.archive.ubuntu.com/ubuntu bionic/restricted amd64 Packages
100 /var/lib/dpkg/status
which is good for my Dell Precision M4800 laptop.
Then I shut down, and moved the USB pendrive to some computers with Intel graphics and one computer with Radeon graphics. An Intel driver and a radeon driver were seleced automatically for the graphics in those cases.
The proprietary nvidia graphics driver caused problems only in a computer with an nvidia chip, that does not work with that driver. Other kinds of graphics chips/cards work well.
I created small files when running in the different computers in order to keep record of the test data, for example
bash -c 'apt-cache policy nvidia-384;sudo lshw|head;sudo lshw -C display' > dell-m4800.txt
$ cat dell-m4800.txt
nvidia-384:
Versionstabell:
tester-system-product-name
beskrivning: Bärbar dator
produkt: Precision M4800 (Precision M4800)
tillverkare: Dell Inc.
version: 01
serienummer: 6KH5Q12
bredd: 64 bits
förmågor: smbios-2.7 dmi-2.7 smp vsyscall32
konfiguration: boot=normal chassis=laptop sku=Precision M4800 uuid=44454C4C-4B00-1048-8035-B6C04F513132
-core
-display
beskrivning: VGA compatible controller
produkt: GK107GLM [Quadro K1100M]
tillverkare: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
bredd: 64 bits
klocka: 33MHz
förmågor: pm msi pciexpress vga_controller bus_master cap_list rom
konfiguration: driver=nvidia latency=0
resurser: irq:32 memory:f4000000-f4ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(storlek=128) memory:f5000000-f507ffff
*-display
produkt: 4th Gen Core Processor Integrated Graphics Controller
tillverkare: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
version: 06
bredd: 64 bits
klocka: 33MHz
förmågor: msi pm vga_controller bus_master cap_list rom
konfiguration: driver=i915 latency=0
resurser: irq:29 memory:f5400000-f57fffff memory:d0000000-dfffffff ioport:f000(storlek=64) memory:c0000-dffff
You can see that this Dell can use the nvidia driver for the nvidia card and the intel i915 driver for the built-in graphics chip.
The corresponding results from all the tested computers can be extracted from the files via the following grep command line,
$ grep konfiguration *.txt|grep latency
dell-m4800.txt: konfiguration: driver=nvidia latency=0
dell-m4800.txt: konfiguration: driver=i915 latency=0
HP-Compaq-Pro-6305-SFF_AMD-A6-6400B-APU-w-Radeon.txt: konfiguration: driver=radeon latency=0
lenovo-i3.txt: konfiguration: driver=i915 latency=0
M2N-VM_DV_Athlon-64-X2-4400.txt: konfiguration: latency=0
NUC6i3SYH-i5.txt: konfiguration: driver=i915 latency=0
toshiba-i5.txt: konfiguration: driver=i915 latency=0
You find no driver reported in the output for the computer with the M2N-VM DV motherboard and an old nvidia chip, that defaults to 640x480 VGA graphics with the proprietary driver. (In order to get good graphics in that computer, I must remove the proprietary driver, so that it can use the built-in nouveau driver and produce good graphics.)
