[ 108.138078] ata1.00: exception Emask 0x10 SAct 0x40000 SErr 0x400100 action 0x6 frozen
[ 108.138085] ata1.00: irq_stat 0x08000000, interface fatal error
[ 108.138090] ata1: SError: { UnrecovData Handshk }
[ 108.138095] ata1.00: failed command: WRITE FPDMA QUEUED
[ 108.138106] ata1.00: cmd 61/c8:90:00:10:c6/03:00:5f:00:00/40 tag 18 ncq dma 495616 out
res 40/00:94:00:10:c6/00:00:5f:00:00/40 Emask 0x10 (ATA bus error)
[ 108.138111] ata1.00: status: { DRDY }
[ 108.138116] ata1: hard resetting link
[ 108.453212] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 108.465868] ata1.00: configured for UDMA/133
[ 108.465881] ata1: EH complete
[ 118.396927] ata1.00: exception Emask 0x10 SAct 0x8000 SErr 0x400100 action 0x6 frozen
[ 118.396936] ata1.00: irq_stat 0x08000000, interface fatal error
[ 118.396942] ata1: SError: { UnrecovData Handshk }
[ 118.396949] ata1.00: failed command: WRITE FPDMA QUEUED
[ 118.396964] ata1.00: cmd 61/50:78:d8:44:a8/03:00:70:00:00/40 tag 15 ncq dma 434176 out
res 40/00:7c:d8:44:a8/00:00:70:00:00/40 Emask 0x10 (ATA bus error)
[ 118.396970] ata1.00: status: { DRDY }
[ 118.396978] ata1: hard resetting link
[ 118.712315] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 118.725463] ata1.00: configured for UDMA/133
[ 118.725485] ata1: EH complete
[ 133.731533] ata1.00: exception Emask 0x10 SAct 0x7c00 SErr 0x400100 action 0x6 frozen
[ 133.731537] ata1.00: irq_stat 0x08000000, interface fatal error
[ 133.731540] ata1: SError: { UnrecovData Handshk }
[ 133.731543] ata1.00: failed command: WRITE FPDMA QUEUED
[ 133.731549] ata1.00: cmd 61/f0:50:c8:17:91/00:00:70:00:00/40 tag 10 ncq dma 122880 out
res 40/00:74:70:a4:85/00:00:70:00:00/40 Emask 0x10 (ATA bus error)
[ 133.731552] ata1.00: status: { DRDY }
[ 133.731554] ata1.00: failed command: WRITE FPDMA QUEUED
[ 133.731559] ata1.00: cmd 61/a8:58:d8:64:91/02:00:70:00:00/40 tag 11 ncq dma 348160 out
[ 133.731562] ata1.00: status: { DRDY }
[ 133.731564] ata1.00: failed command: WRITE FPDMA QUEUED
[ 133.731569] ata1.00: cmd 61/08:60:78:13:84/00:00:70:00:00/40 tag 12 ncq dma 4096 out
[ 133.731572] ata1.00: status: { DRDY }
[ 133.731574] ata1.00: failed command: WRITE FPDMA QUEUED
[ 133.731579] ata1.00: cmd 61/08:68:b8:13:84/00:00:70:00:00/40 tag 13 ncq dma 4096 out
[ 133.731581] ata1.00: status: { DRDY }
[ 133.731583] ata1.00: failed command: WRITE FPDMA QUEUED
[ 133.731588] ata1.00: cmd 61/10:70:70:a4:85/00:00:70:00:00/40 tag 14 ncq dma 8192 out
[ 133.731591] ata1.00: status: { DRDY }
[ 133.731594] ata1: hard resetting link
[ 134.047939] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 134.061108] ata1.00: configured for UDMA/133
[ 134.061136] ata1: EH complete
Asked
Active
Viewed 2.3k times
SurvivalMachine
- 2,843
You have NCQ disk errors, See here
Edit your /etc/default/grub file and change the following:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash libata.force=noncq"
Save the changes and update GRUB, and reboot:
sudo update-grub
reboot
And see if the problem is solved. If not, undo these changes, and suspect a bad SATA port, SATA cable, or a possible bad hard drive.
heynnema
- 73,649
