Before you mark my answer as a duplicate, please read.
I am facing ghost touch issues with my touchscreen on my Dell laptop. I have read through almost all answers here and on other sites and the issue still persists.
Here were some pointers I got.
Suggestion 1: Head over to /usr/share/X11/xorg.conf.d/10-evdev.conf
Situation 1: No such file. I only have 40-libinput.conf
Suggestion 2: In whatever file you have, edit the touchscreen section to add
Option "Ignore" "on"
Situation 2: No effect
Suggestion 3 : In whatever config file you have turn the match to off.
MatchIsTouchscreen "off"
Situation 3 : No effect. Sometimes it freezes in the login screen and have to reboot the system.
Suggestion 4 : Find the xinput id of the driver and kill it. Since the id can change anytime, use the name.
Situation 4 : I am a beginner, I ended up writing this piece of shell script.
#!/bin/bash
xinput | while read line ;
do
if [[ $line =~ .*Touchscreen.* ]]
then
idString=$(echo $line|cut -d'=' -f 2)
id="${idString%%[*}"
id=$(echo "$id" |xargs)
echo "Going to Disable Touchscreen with Id: $id"
xinput disable $id
fi
done
(The above code was tested successfully when one day the ghost touches magically stopped for a day. I re-enabled it and re-tested. Do point out any mistakes if any, but for the love of god, please do not give me a fancy way to do the same thing)
I was asked to place this in /etc/X11/xinit for global effect and in /home/.config/autorun for user specific effect. I made the script executable as can be seen,
-rwxr-xr-x 1 root root touchscreen_killer.sh*
Now although this seems to work, It does not work always. Every now and then I end up facing ghost touches again, and am unable to even go past the login screen. Even if I do, the ghost touches open up a huge number of applications forcing the PC to finally crash. Hence unable to carry out the silly suggestions like manually finding xinput id and disabling it that I saw in many other answers.
So still I have NOT been able to PERMANENTLY disable my touch screen. It bugs me that it is so easy in Windows. I just disabled the touch screen in Device Manager and windows works fine thereafter. But Ubuntu is is giving me a hard time.
If anyone has any solution that is not mentioned above, please do share. HELP !!
