-1
Running this very simple Dockerfile
FROM ubuntu:17.04
RUN apt-get update
fails with these errors:
W: The repository 'http://security.ubuntu.com/ubuntu zesty-security Release' does not have a Release file.
W: The repository 'http://archive.ubuntu.com/ubuntu zesty Release' does not have a Release file.
W: The repository 'http://archive.ubuntu.com/ubuntu zesty-updates Release' does not have a Release file.
W: The repository 'http://archive.ubuntu.com/ubuntu zesty-backports Release' does not have a Release file.
E: Failed to fetch http://security.ubuntu.com/ubuntu/dists/zesty-security/universe/source/Sources  404  Not Found [IP: 91.189.91.23 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/zesty/universe/source/Sources  404  Not Found [IP: 91.189.88.161 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/zesty-updates/universe/source/Sources  404  Not Found [IP: 91.189.88.161 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/zesty-backports/universe/binary-amd64/Packages  404  Not Found [IP: 91.189.88.161 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
This looks like a Ubuntu problem rather than a Docker problem. Is there a workaround?
Ubuntu 17.04, Released in 2017.April (hence 17.04) is a short-term or standard Ubuntu release; with a supported life of 9 months only.
Ubuntu 17.04 users were prompted to upgrade to 17.10 (the 2017.October release), however it too is now EOL (but users were prompted to upgrade to 18.04 LTS).
Post a release reaching EOL; its repos are moved from archive.ubuntu.com to old-releases.ubuntu.com which occurred long ago with 17.04; but hasn't yet occurred with 17.10 (it only very recently reached its EOL; in a few weeks its repositories will be moved too)
If you want/need a longer life, use long-term-support releases, such as Ubuntu 14.04 LTS (2014.April), 16.04 LTS (2016.April) & 18.04 LTS (2018.April) with a supported life of 5 years each.
guiverc
  • 33,561
