I had an issue with my external HD monitor which started flickering and the rows of pixels were unaligned with each other a bit so the picture was kind of blurry. I tried everything from changing some settings to a different kernel and nothing worked.
VaNa
  • 333
12 Answers12
11
Finally a simple change of resolution from 1920 x 1080i to 1920 x 1080 (at Settings - Devices - Displays - [choose the problematic display] Resolution) worked.
Just putting it out there if someone ever stumbled upon this problem.
Zanna
  • 72,312
VaNa
  • 333
I've similar problems with my monitor&Ubuntu18(laptop). After some investigation, I fixed this problem and found the root cause in my environment.
My problem's root cause is in the HDMI signal quality, and the HDMI signal poor quality has two root causes:
  1. The HDMI cable;
  2. The HDMI cable doesn't plug into the socket closely;
My final solutions are as:
  1. Re-plugin the cable with your PC and monitor, and secure them carefully;
  2. Buy and use a new high-end HDMI cable(above 20$, seller should claim it support 4K or 8K);
  3. If you couldn't do the 2nd solution, and the problem still exists, lower your display configuration just like the solutions provided by others in this issue, e.g. lower the display resolution to 720P, or lower the display frequency. These lower resultion doesn't require high signal quality transferring capability in your cable, so they could work without problem.
Clock ZHONG
  • 1,015
  • 13
  • 17
I had this problem with a Samsung curve screen external monitor on Ubuntu 18.04.3 LTS
To solve it I tried with different resolution aspect ratio. Specifically it was 16:9 for external and I changed it to 16:10. After that, it worked fine, and no need to restart the machine in my case.
Zanna
  • 72,312
Make sure your monitor refresh rate and settings match.
Go to Settings > Devices > Displays
Check your monitor maximum Hz (do not include freesync or other support only base maximum Hz.)
Make it same for example if your monitor supports max 60Hz and 75Hz with freesync, then go to settings and make it 60Hz.
Zanna
  • 72,312
sudo vi /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash intel_idle.max_cstate=4"
sudo update-grub
reboot
What worked for me was to change the frequency to 60Hrtz. Somehow it had changed to 30Hrtz after a restart.
mic
  • 111
Assign the same refresh rate to both monitors.
settings --> display --> select the 1st monitor --> Refresh Rate --> 60Hz
Again, select the 2nd monitor --> Refresh Rate --> 60Hz
I'm using a 4k external monitor and this is what worked for me: I tried lowering Refresh Rate for my external monitor from 60Hz to 50Hz.
My assumption is that the HDMI cable can't deliver 4k 60Hz. Using a displayport cable should solve the issue without lowering the refresh rate.
Mik
If you have a DisplayPort cable, and the image flickers on a higher resolution and/or higher refresh rate (for me it was okay for 3440x1440 30Hz, and flickering on higher refresh rate; also 1720x1440 60Hz was okay):
  • Try to change the DP capability from DP1.2 to DP1.1
This helped me
NonGrate
  • 111
Try lowering your maximum resolution one level.
From Your Max Resolution: 1366 x 768 (16:9)
To One Level Less: 1280 x 720 (16:9)
GL
Braian Coronel
  • 403
Finally this appears to be fixed in Kernel 6.1.8 . I have 3 external monitors connected to an Intel nuc7 that have been flashing for a long time now to the point I have been leaving them unplugged and testing new kernels.
Install 'Ubuntu Mainline Kernel Installer' which will enable you to select which newer mainline kernels you want to run.
Kernel 6.1.8 no flashes for hours where I used to get flashes every few seconds.
Alex
In my case this method works
Open Software & Updates > Additional Drivers and select driver related to my laptop Graphic card and Apply changes.
Don't forget to reboot after successfully update.
VR Patel
