When trying to install python-gtk2, I get the following errors:
sudo apt-get install python-gtk2
Reading package lists... Done
Building dependency tree
 python-gtk2 : Depends: python (< 2.8) but 3.4.3-1 is to be installed
               Depends: python:any (>= 2.6.6-7~)
               Depends: python-cairo (>= 1.0.2-1.1) but it is not going to be installed
               Depends: python-gobject-2 (>= 2.21.3) but it is not going to be installed
But I have python2.7 installed. When I run python in terminal, it works properly (Python 2.7.15rc1 (default, Apr 15 2018, 21:51:34)). What should I do in this situation? Things I have tried include:
  • sudo apt-get -f install
  • sudo apt-get update –fix-missing
  • sudo dpkg –configure -a
After running sudo apt-cache policy python I get this output:
python:
  Installed: 3.4.3-1
  Candidate: 3.4.3-1
  Version table:
 *** 3.4.3-1 100
        100 /var/lib/dpkg/status
     2.7.15~rc1-1 500
        500 http://us.archive.ubuntu.com/ubuntu bionic/main amd64 Packages
karel
  • 122,292
  • 133
  • 301
  • 332
What ended up working was:
sudo apt-get install python=2.7.15~rc1-1
Then, after running apt-cache policy python,
python:
  Installed: 2.7.15~rc1-1
  Candidate: 2.7.15~rc1-1
  Version table:
 *** 2.7.15~rc1-1 500
and I could install my package. This had the effect of removing my python3.4 I believe.
