I have a specific workspace that I must navigate to that is annoyingly long. like/really/damn/annoyingly/long/and/it/takes/a/while/to/type. I wanted to write a shell script that would just cd me into it, but of course, that won't work. Is there another way to make it so I can just cd into this directory without the hassle of typing it out?
Don't tell me copy and paste.
Thank you!
You can't use a shell script to change directory, because the script runs in a different process and that child process cannot alter the environment of the current shell process.
You need to write a function or alias that will operate in your current interactive shell. One of these will work:
alias go='cd /really/damn/annoyingly/long/and/it/takes/a/while/to/type'
# or
go() { cd /really/damn/annoyingly/long/and/it/takes/a/while/to/type; }
Pick one, save it in your ~/.bashrc, type source ~/.bashrc and you should be ready to go.
glenn jackman
  • 18,218
Symlink
You could use a symlink, which is a special type of file that links to another file:
ln -s "/really/damn/annoyingly/long/and/it/takes/a/while/to/type" link_name
This creates a symlink called link_name which links to /really/damn/annoyingly/long/and/it/takes/a/while/to/type.
Then, in a shell:
~$ cd link_name
~/link_name$
Shell variable
Or create a variable:
variable_name='/really/damn/annoyingly/long/and/it/takes/a/while/to/type'
Put that in your ~/.bashrc, run source ~/.bashrc, then you can simply cd "$variable_name".
wjandrea
  • 14,504
Actually you CAN cd in a script -- just put your cd command in a script. You have to execute it like this though: . ./script1. The . in front causes the script to run in your current shell instead of launching a new one.
~$ cat script1
cd ./ISO
~$ . ./script1
~/ISO$
wjandrea
  • 14,504
