I have installed elasticsearch . This is how I am running it currently.
cd /elasticsearch-6.3.1/bin
./elasticsearch
It is working fine. But, I want to run this program as a service. Like, I want to run it like,
sudo service elasticsearch restart
It should run the elasticsearch. I have tried to create a script in /etc/init.d , but it is not working. This is what I did,
cd /etc/init.d
sudo vim elasticsearch
This is content in that file,
./elasticsearch
What is the recommended way to achieve this ?
Create an upstart script like the following
# ElasticSearch upstart script
description     "ElasticSearch service"
start on (net-device-up
          and local-filesystems
          and runlevel [2345])
stop on runlevel [016]
respawn
respawn limit 10 30
# NB: Upstart scripts do not respect
# /etc/security/limits.conf, so the open-file limits
# settings need to be applied here.
limit nofile 32000 32000
setuid elasticsearch
setgid elasticsearch
exec /path/to/elasticsearch/bin/elasticsearch -f -Des.default.config=/path/to/config/elasticsearch.yml -Des.default.path.home=/usr/share/elasticsearch/ -Des.default.path.logs=/var/log/elasticsearch/ -Des.default.path.data=/var/lib/elasticsearch/ -Des.default.path.work=/tmp/elasticsearch -Des.default.path.conf=/path/to/config/
Replace the paths with the absolute paths in your case. Save this as elasticsearch.conf in /etc/init/
Also note that you're best off running elasticsearch as it's own user (hence the setuid and setgid lines)
Amith KK
  • 13,547
