Recently the touchpad right-button stopped working as such and instead started behaving a left-button. For example, when I select text and right-click, instead of the expected context menu, the text gets deselected.
My mouse's right-button does work as expected.
It's a Dell Inspiron 7577 with Ubuntu 18.04 LTS.
How can I resolve this?
Joshua Fox
  • 3,011
Here is the answer.
Summary:
  1. Ubuntu 18.04 changed touchpad behavior: By default, you "right-click" by tapping with two fingers.
  2. You can get back the right-button by installing gnome-tweaks, then Keyboard and Mouse -> Area.
Joshua Fox
  • 3,011
You can set it without installing gnome tweaks using
gsettings set org.gnome.desktop.peripherals.touchpad clickmethod "areas"
To set it back use
gsettings set org.gnome.desktop.peripherals.touchpad click-method "fingers"
abu_bua
  • 11,313
Apparently you reversed them. Go into Settings, then Keyboard & Mouse. At the top you'll see where you can select which is your 'main mouse button'. Click left and then you're all set!
Ulvdet
