how do you play wot on unbuntu.I`m new to linux os and know how to do about nothing on how to use it.
Just works under wine 3.21-staging and up.
Current stable version is 4.0.
Based on wine application database, the game has gold status, which means it should work without any problems. If something turns out, check the linked website for all the available workarounds.
Install
If your system is x64, you need to enable x86 architecture
sudo -i
dpkg --add-architecture i386
Download and add the repository key
wget -nc https://dl.winehq.org/wine-builds/winehq.key
apt-key add winehq.key
Add the repository based on your ubuntu version
One line here is one command for terminal. Use copy-paste.
apt-add-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ cosmicmain'
apt-add-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ bionicmain'
apt-add-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ xenialmain'
apt-add-repository 'deb https://dl.winehq.org/wine-builds/ubuntu/ trustymain'
Update packages with apt update
Install one of the following packages
Note, that there is no space between winehq-stable etc.
sudo apt install --install-recommends winehq-stable
sudo apt install --install-recommends winehq-devel
sudo apt install --install-recommends winehq-staging
- 465
