Bash doesn't have a goto operator. I have a simple task, and I can't figure out how to solve it without goto or adding a new proc, and that is undesireable.
I have two conditions and a block of code that should work this way:
[ condition 1 ] if true run some commands and check [ condidion 2 ]; if false exec a block of code.
[ condition 2 ] if true don't exec the same block of code; if false do execute the same block.
Is it solvable, or I have to define some proc and use exit there? I used a flag var, but I don't like it.
With goto available it would look this way:
[ cond 1 ] || goto label 1
  command
  command
  [ cond 2 ] && goto label 2
:label 1
block of code
:label 2
Something like that.
Pilot6
  • 92,041
The typical way to work to use branching in shell scripts would be via functions declared before main block of code. However, I think the underlying issue here is the logical one, and not the goto. Obviously label 1 is repeated, so this can live as function. But also, condition 2 could be turned into a function that also calls label 1 for the sake of readability:
#!/bin/bash
label1(){
    echo "label 1 function"
check_cond2(){
    if ! [ condition2 ]; then
        label1 arg1 arg2
    fi
if [ condition1  ]; then
    command
    command
    check_cond2
else
    label1
fi
othercommand2
othercommand3
What I've noticed is that in both conditions you have if false exec a block of code and if false exec a block of code, so one idea would be to start at checking whether those conditions both false. However, making something like if ! [ cond1 ] || ! [ cond2 ] would change branching logic. You can still see the pseudocode version of that by seeing this posts edit history.
13
When I moved from Windows to Linux on my desktop, I had a lot of pre-existing .BAT and .CMD files to convert and I wasn't going to rewrite the logic for them, so I found a way to do a goto in bash that works because the goto function runs sed on itself to strip out any parts of the script that shouldn’t run, and then evals it all.
The below source is slightly modified from the original to make it more robust:
#!/bin/bash
BAT / CMD goto function
function goto { label=$1 cmd=$(sed -n "/^:[[:blank:]][[:blank:]]*${label}/{:a;n;p;ba};" $0 | grep -v ':$') eval "$cmd" exit }
apt update
Just for the heck of it: how to create a variable where to jump to:
start=${1:-"start"} goto "$start"
: start goto_msg="Starting..." echo $goto_msg
Just jump to the label:
goto "continue"
: skipped goto_msg="This is skipped!" echo "$goto_msg"
: continue goto_msg="Ended..." echo "$goto_msg"
following doesn't jump to apt update whereas original does
goto update
and I do not feel guilty at all as Linus Torvalds famously said:
Subject: Re: any chance of 2.6.0-test*?
Date: Sun, 12 Jan 2003 11:38:35 -0800 (PST)
I think goto's are fine, and they are often more readable than large amounts of indentation. That's especially true if the code flow isn't actually naturally indented (in this case it is, so I don't think using goto is in any way clearer than not, but in general goto's can be quite good for readability).
Of course, in stupid languages like Pascal, where labels cannot be descriptive, goto's can be bad. But that's not the fault of the goto, that's the braindamage of the language designer.
Original source for the code (modified to make it less error prone)
The source for the quote
Fabby
  • 35,017
11
You should put your block_of_code into a function and use some if/else:
my_function() {
    block of code
if [[ condition 1 ]] ; then
    command
    command
    if [[ ! condition 2 ]] ; then
        # label 1
        my_function
    fi
else
    # label 1
    my_function
fi
# label 2
Byte Commander
  • 110,243
