My taskbar on the left side displays the system monitor symbol. By just clicking on it, I was able to open it. But suddenly, it stopped working. I clicked on it and Ubuntu seemed to load and open the process but quitted doing so after a while – and acted as if I have never clicked on that button. Yesterday, everything was still fine. Today, Ubuntu is acting that weird.
It does this sometimes if you keep your system running for days without restart.
to solve this whenever it happens:
Run in the terminal
killall gnome-system-mo
then
gnome-system-monitor
it should work fine after this.
- 34,963
Gnome-system-monitor is not installed as part of Gnome on Ubuntu, but instead, for some vague reason Ubuntu installs it as a snap app. This is why your apt commands did not work.
To install gnome-system-monitor as part of gnome, you must first uninstall the snap version:snap remove gnome-system-monitor
after that you can install native gnome-system-monitor with apt: sudo apt install gnome-system-monitor
- 527
First, I have tried to install the system monitor all over again by typing sudo apt install gnome-system-monitor into my terminal. This did not work. I tried to uninstall it with sudo apt purge gnome-system-monitor and install it again with sudo apt-get install gnome-system-monitor. It still did not work. So, I just typed in gnome-system-monitor and it worked. But it was displayed as a separate instance on my taskbar. So, I just deleted the old link and made myself a new one. Now, everything is fine again.
- 167
