This is the notice I get:
The file '/home/heart/Phantombot/PhantomBot-2.4.1/PhantomBot.jar'
is not marked as executable.  If this was downloaded or copied
from an untrusted source, it may be dangerous to run.
For more details, read about the executable bit.
Basically, the JAR file doesn't have the necessary permission to run. How do I give it this permission?
Rinzwind
  • 309,379
To add executable bit to a file, use this construction:
chmod +x /path/to/file
The command for your jar file is
chmod +x /home/heart/Phantombot/PhantomBot-2.4.1/PhantomBot.jar
if you'are owner of the file.
If you aren't owner of the file, use leading sudo:
sudo chmod +x /home/heart/Phantombot/PhantomBot-2.4.1/PhantomBot.jar
Bob
  • 2,563
