-1
I'm trying to assign multiple variables to load into a pipeline. I want to prompt the user for values and then read them into variables. My current script is:
echo "How many galaxies are you analyzing?"
read n1
i=1
while [$i -lt $n1]; do
echo "Please list galaxy $i."
read gal${i}
echo "How many observations are there for gal${i}?"
read n2
while [$j -lt  $n2]
echo "Please enter observation #$j for gal${i}."
read obs${j}
echo gal${i}
echo obs${j}
let j++
done
echo gal${i}
let i+1
done
I would like for there to be a tree consisting of
├── gal1
|   ├── obs1
│   └── obs2
├── gal2
│   ├── obs1
│   ├── obs2
│   └──obs3
where these values are any alphanumeric combination.
The error I'm getting when I run the loop above is:
user@user:~$ bash tst.tst
tst.ts: line 16: syntax error near unexpected token `done'
tst.ts: line 16: `done'
wjandrea
  • 14,504
J. Doe
  • 333
First, indent your code so it's logical structure is more easily viewed (many editors will do this for you, but it's worth doing manually if you must):
#!/bin/bash
read n1
i=1
while [[ $i -lt $n1 ]]; do
    read gal${i}
    read n2
    while [[ $j -lt  $n2 ]] ; do
        read obs${j}
        echo gal${i}
        echo obs${j}
        let j++
    done
    echo gal${i}
    let i+1
done
Second, the first line should be "#!/bin/bash".
Third, line while [$j -lt $n2] needs a ; do after it.
Fourth, using [ runs /usr/bin/test every time. Using the bash builtin [[ (and ]]) is better.
"I would like for there to be a tree...". It's a SMOP (Simple Matter of Programming), and you will have to arrange the data the way you need it. However, building trees in bash is unecessarily hard, when perl, python, ruby, etc exist.
waltinator
  • 37,856
